Home > Maintenance & Modifications > Parrot Asteriod |
Revived a memory or two there.....I actually in approximately 1979 ish had a Mk 1 Escort that had an 8 track fitted under the dash. Due to the size of the cartridges you'd only have room for two or three of them in the vehicle or you had to sacrifice passenger space if you wisjhed to carry more of them, slot them in and listen to the clunk and whirring before the music commenced. My how we've advanced. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
11th Oct 2012 7:55am |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 |
Pics as promised..
Ram mount for iPhone and connectivity lead coming through air vent. Mic on mirror base. 993 Varioram - Guards Red Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
11th Oct 2012 4:48pm |
Pics as promised..
Ram mount for iPhone and connectivity lead coming through air vent. Click image to enlarge Mic on mirror base. 993 Varioram - Guards Red Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
11th Oct 2012 4:49pm |
brightondefender Member Since: 14 Jan 2012 Location: East Sussex Posts: 97 |
got mine all fitted - really happy with it the only slight disappointment was that I couldnt change the display to gree to match but nothing worth complaining about
quick question - where did everyone mount their GPS receiver? I have put mine on the underside of the top of the dash but not sure if it needed a line of sight to the sky..... |
13th Oct 2012 12:10pm |
In the middle of the top of the dash nearly touching the windscreen, in line with the clock....Line of sight is always best. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
13th Oct 2012 12:17pm |
Geoff 90 Member Since: 21 Jan 2012 Location: Wexford/Dublin Posts: 26 |
I got a present of a parrot asteroid for Christmas fitted it an love it it's great for streaming music to which is handy. Having a problem with it lately and I'm sure it has happened to others who have the unit. As I'm driving along it just crashes turns itself off for a few seconds and then turns itself back on again. Is it a problem with the head unit do I need to return it or is there something I can do to fix it!?
Cheers Geoff |
24th Jan 2013 4:11pm |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1579 |
Updated mine a week ago now and it's even better.
You must reset the unit before reinstalling. A friend of mines stopped working went completely blank. You take the cover off and hold the reset in for 20 seconds. Put the cover back Put a memory stick in with the latest update Press and hold the parrot and white button and it updates. To reconnect your iphone you need to delete it of your connections list and re-search it. I've put this on as I've heard a few people have said theirs has died. Having seen a dead one now full of life might be worth a go. The update now talks English and can say people's names right. Also you say accept to answer calls which makes it proper hands free. Also am convinced it sounds better but that is probably just me. |
18th Aug 2013 1:03pm |
