Home > Maintenance & Modifications > Request for JW Speaker LED photos |
[quote="mobilecentre"]
Good advice! Unfortunately it was me that opened the stable door and let that horse bolt ages ago! It goes without saying and without wishing to blow too much sunshine up Tim's crimper the goods and service he supplies is excellent. I could always cash in and stick my spare lens up for sale at about £200 by my reckoning. Needless to say knowing my luck the day after it's sold I'd experience another breakage so I daren't. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
9th Oct 2012 12:01pm |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 |
Your son was issued with a PC cup with lid and straw which is much more impact tolerant |
9th Oct 2012 2:47pm |
Click image to enlarge Unplug old and plug in new! |
9th Oct 2012 4:27pm |
A bit off topic but not entirely.... Next week my just arrived Speaker 8700s will be installed, replacing my standard H4 main headlamps on my SVX. Those are wired now directly via the switch I know, which understand is far from ideal for the risk of the switch overheating, power loss/sub-optimal light output, etc....... This has been covered many times here.
My question is if it would be a good idea to ask my dealer when he will change the H4s for the LEDs to also rewire them via a relay? I don't think with the 2.5 instead of 4.5 Amps consumption per headlamp there will be much risk for the switch to overheat in the future, but would getting the power directly from the battery as opposed to via the switch mean that the new LEDs will also give more light as would be the case with halogens? Or with LEDs which seem to function on anything between 12 and 24V maybe it makes no difference? Let me know pls. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
9th Oct 2012 4:56pm |
I normally supply the hob nobs as well |
9th Oct 2012 6:09pm |
There will be no difference to light output using relays with the LEDs, the lower current draw will reduce load on the switch so I would leave as standard |
9th Oct 2012 6:10pm |
brightondefender Member Since: 14 Jan 2012 Location: East Sussex Posts: 97 |
Hi SGH where did you get your KBX grill from? Did you have it sprayed in grey? Mines Stornaway and I wondered what it would look like with grey grills - have to say it looks the dogs dangles |
10th Oct 2012 9:58pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
id say go grey mate looks really nice all colour coded, you could do with some colour coded mirrors and dash next though now who sells them CSK Automotive
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
10th Oct 2012 10:01pm |
I don't know killer who does sell all those things? Don't suppose you sell the KBX grills? Last edited by brightondefender on 10th Oct 2012 10:05pm. Edited 1 time in total |
10th Oct 2012 10:04pm |
CSK Automotive
10th Oct 2012 10:05pm |
Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
10th Oct 2012 10:10pm |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 |
I thought he only supplied top of the range chocolate ones!
11th Oct 2012 5:29am |
Paddocks are the most reasonable I believe..... but they don't do colour coding unless you have Java, Brunel or Zambezi..... http://www.google.co.uk/#q=kbx+defender+fr...mp;bih=575 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
11th Oct 2012 6:41am |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1385 |
,Tim brought a box from Bookers, we have Chocolate ones all over the unit.. Putting Dreams on Drives at JLR Solihull.. |
11th Oct 2012 7:15am |
