Home > Puma (Tdci) > Decat - is it worth it?
Page 3 of 8 <12345678>
ZeDefender
K9F wrote:
Ze,
I've got a catalytic convertor off my Puma languishing in my garage if you're interested? Thumbs Up
Would be the ideal solution Very Happy
If I can figure out postage to Germany, still willing?
Matt
p.s. we don't seem to have scrap yards, as such, around here and they want silly money for old cr*p Evil or Very Mad Tell someone you love them today because life is short.
Post #173529 6th Oct 2012 8:20am
K9F
No sweat....Kraut another forum member from Westfalia is over here somewhere at the moment? Wonder if he's heading south at any point? Could do a bit of a relay if it suits everyone?
Just an idea..... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #173530 6th Oct 2012 8:24am
ZeDefender
PM sent Thumbs Up Tell someone you love them today because life is short.
Post #173531 6th Oct 2012 8:28am
ZeDefender
T1G UP wrote:
i have taken a standard cat front pipe, filled it with water, drilled some big holes in the cat itself until it broke up. then tipped it out into our incinerator. repeat until empty...easy, standard looking and de-catted Thumbs Up
Thanks again for the info When you say you drilled some big holes in the cat, I'm guessing you welded them up afterwards? Or am I hopelessly off-track (as usual) Rolling Eyes
And the water? Tell someone you love them today because life is short.
Post #173535 6th Oct 2012 8:51am
wslr
Another option would be to fit a tri metallic sports cat to the downpipe. Probably adding £150 to the cost of building the downpipe, but offers a pretty much free flowing system up front and it is a cat unit for inspection.
Post #173540 6th Oct 2012 9:24am
T1G UP
And the water?
Yes your miles out!
when you look into the turbo end of the cat pipe you can see the honey comb of the cat.
I bloked the other end off, filled the pipe with water to stop the dust then drilled through the honey comb ,NOT the body of the cat, with a 15mm masonry drill bit to break up the cat. Then tipped the bits out. filled again and repeated until the cats gone. then you'll have an empty standard down pipe Thumbs Up 20 minutes tops and i had a cup of assam aswell during the operation Rolling with laughter
Post #173541 6th Oct 2012 9:32am
K9F
T1G UP wrote:
Yes your miles out! when you look into the turbo end of the cat pipe you can see the honey comb of the cat.
All over it T1G..... Thumbs Up Sorry for picture quality....
Decat pipe assembly.......
Utilising my 6 year old daughter to hold the torch you can just see the light on the fine mesh of the internals of the catalytic convertor looking in the turbo end. It is this that must be removed.
No comments please about my shagpile rug, but SWMBO wasn't happy when she saw my 'pipe' being wiped on it..... Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #173542 6th Oct 2012 9:51am
rusty66
Germany
ZeDefender wrote:
You know I heard this before but didn't believe it. Scangauge eliminates AU then? Thumbs Up
Yes, that's right, as well as any other cheap ECU code reader. As long as the erased error code wouldn't appear again during TUV testing.
Post #173544 6th Oct 2012 10:18am
ZeDefender
T1G UP wrote:
Yes your miles out!
Er, yes Embarassed
Realised that, then wifey made me go out before I could ***delete*** the post Thud
Many thanks - looks like Mal is sorting me out Thumbs Up
Matt Tell someone you love them today because life is short.
Post #173547 6th Oct 2012 11:08am
ZeDefender
Er...who can calculate the volume of a downpipe, please?
So far, DHL, Fed-Ex and UPS all want to know the volume, otherwise they ignore the real weight and calculate it based on a box it would roughly fit in = 45 Kg = £300 Shocked Shocked Shocked
Help!
Post #173552 6th Oct 2012 11:37am
rusty66
Germany
Are you sure they mean the volume of the pipe or the volume of the box that will hold it? First option wouldn't make sense to me.
My experience with German couriers is that they want the three lengths of the box and add them up and this gives them the size they are going to charge you for.
Must say though, that it seems freight / postage from the UK to the mainland is much higher than the other way round and within the continent. No idea why this is so Neutral
Post #173553 6th Oct 2012 11:54am
ZeDefender
Yep - real volume of pipe Rolling Eyes
Nice lady at DHL said if I give her the real volume (not box volume) they will calculate the weight that way, saving a lot of money Thumbs Up
Post #173554 6th Oct 2012 12:03pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
length of pipe x((Diameter of pipe squared divided by 144) x .7854) = cuft
i.e. 3" pipe 10ft long =
(((3*3)/144) x .7854)*10 = .4908 cuft
cuft x 28316.8 = Cubic centimetres.
cuft x .028316846 = Cubic Metres Original Member Pie n Pea Club.
110 HCPU Tipper
Post #173555 6th Oct 2012 12:37pm
ZeDefender
Bow down Tell someone you love them today because life is short.
Post #173556 6th Oct 2012 12:44pm
K9F
All sorted now. Organising postage from this end involves significantly less hassle and less expenditure even with Fed-Ex who happens to be one of the cheapest. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #173586 6th Oct 2012 4:37pm
