![]() | Home > Puma (Tdci) > Decat - is it worth it? |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 810 ![]() ![]() |
Depends if the Calibration is matched to the exhaust? You might find your Defender will end up surging as turbo is trying to control... which isn't ideal. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8221 ![]() ![]() ![]() |
ok, cheers, food for thought. Cheers
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 362 ![]() |
I read this (old) thread with interest. Did you finally measure CO and HC before and after the de-cat-project and can post the values? Did anyone compare emissions before and after the de-cat? Important would be the milage of the vehicle as well to evaluate the potential coating of the cat-cells that causes reduced output/catalysis... |
bos Member Since: 11 Feb 2016 Location: Dolenje jezero Posts: 9 ![]() ![]() ![]() |
I have 3 decat Defender 2,4 beter drivig, lower consumption cca. 650 km/67 lit. My 2,2 def with DPF 460-510 km/67 lit.
Cheers, so is it better saving primary energy (lower consuption, lower particle emission) or wasting primary energy due to collecting particles and burning them to ash...
thats the description of a DPF not a CAT
Yes! De-cat lowers consumption, DPF rises it. So the question is what's better. Saving energy or particles...
