Home > Technical > Traction control |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 |
+1 2007 TD5 90 Hard Top |
18th Sep 2012 12:59pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17333 |
Yes, not diificult. You'll need a dial gauge to set the backlash, and it helps to have (or make) a special tool for the diff carrier bearing nut adjustment (it is a simple tool to make) but apart from that nothing complex. Be aware that the diff is heavy though, and unless you know what you are in for dropping it out from the axle can be a bit literal. I always make sure that I am directly under the diff so that its fall is broken by something soft! |
18th Sep 2012 3:26pm |
Brucey Member Since: 18 Jul 2012 Location: Warsaw, Poland Posts: 61 |
Lol. Ok, is there an idiots guide anywhere? (sorry am traveling so will Google when I get home). I would expect that Ashcrofts will have an installation guide....maybe. Will take some photos when I get that far. Thanks for the help Chris Defender 110 DC converted Auto BMW R1200GS BMW F650GS Dakar |
18th Sep 2012 3:57pm |
