Home > Technical > Cross Member Bolt sizes
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Lots of searching and I keep coming up with different answers. I need to check for certain what the thread size is in my TD5 cross member for the NATO hitch and the larger tow bar mounts below.
I believe that the NATO is 4 x M12 and the 2 holes below are M16. It's just i've tried M12 in the top hole and I can get one to bite but them it stiffens up as if cutting a new thread and the other won't get close.
Most likely paint. I'll buy a tap to clean it but I wanted to check I want barking up the wrong tree
Post #168150 13th Sep 2012 6:11pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I remember when I changed all my bolts an refitted my NAS step that the two big boys are definitely M16. I didn't need to put any fixings into the upper four so I can't say for sure but I think you're right that they are M12.
Pete
Post #168249 13th Sep 2012 9:37pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
From what I have read td5 cross members are not really that strong for fitting pintles to and you need some serious spreader plates, which in and of it's self means clearence issues with the fuel tank. That said they ought to be m12 assuming no one has messed with them in the past. Rhubarb and custard let fly with their secret weapon.
Post #168285 14th Sep 2012 5:15am
me@td5.org
It will have quite a lot of support when all is done. Unfortunately I can't re-enforce from behind but the hitch is mounted to a plate which will be bolted on all 6 holes which then is fastened below to the chassis mounts for the tow bar.
I'll post pictures up when i'm done.
Post #168296 14th Sep 2012 6:54am
If you haven't already seen them, you might want to look at the following threads:-
http://www.defender2.net/forum/topic12638.html
http://www.defender2.net/forum/topic1876.html
Post #168346 14th Sep 2012 10:26am
me@td5.org
Thanks, read those before. I posted. I was sure they were M12 corse thread. I didn't want to forse them in and create a bigger problem.
I think I have found a good mounting solution that allows my to tow the Sankey at the correct height, maintain the departure angle when off-road and allow me to tow regular trailers at the correct hitch height.
Post #168354 14th Sep 2012 11:43am
