Page 370 of 1376 <123 ... 369370371 ... 137413751376>
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
replaced my turbo cover that had broken... easy job...15 min to do...
the new one in place...
btw, does yours look like this underneath? all rusty ?
Sad Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #168164 13th Sep 2012 8:04pm
Defender-Stu
My TD5 looked like this as its just where it's got hot and reacted with the atmosphere, but could be wrong :/
Post #168193 13th Sep 2012 8:47pm
Today I drove 500 miles with the T@B on tow Shocked
Thankfully, all the money spent on soundproofing must of paid off Smile
Post #168216 13th Sep 2012 9:48pm
Insulated my footwells with some Army insulation stuff from ebay, and tested my spare starter motor, oiled it and packed it away for Feb 2013.
going to be doing some prep work on the roof rack and fit at the w/e ... pics to follow Thumbs Up
Post #168220 13th Sep 2012 9:50pm
T1G UP
well yesterday...very late i went to IRB. Had a drive in Ians 90...what a flyer Thumbs Up wish my 110 went like that.
Also met Lyndsay Porter of LRM fame...lovely chap. We discussed suspension, LEDs, autos (he has all!)
Then we convoyed down the M42 and the M5..great fun. Got home at midnight.
Post #168227 13th Sep 2012 9:57pm
dgardel
Italy
Sad
For the turbo, it is made by cast iron (not steel) and the "rust" it is not rust but superficial passivation (like the exhausts manifold and the engine block). Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #168232 13th Sep 2012 10:07pm
lrmaniac
Thumbs Up learning everyday! thanks! Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #168261 13th Sep 2012 11:15pm
RobKeay
Broke down, left fluid all over road.
Land rover assist came and fixed the pipe.
Same old a clip had punctured the coolant pipe. Gonks at the factory not screwing them together.
Post #168269 14th Sep 2012 12:03am
Rob - glad you are ok and all fixed up, please can you elaborate on the clip/pipe that failed ? Pics would be good Thumbs Up
Post #168290 14th Sep 2012 7:27am
rossy
cleared out the huge clumps of dried muck that accumulate around the ends of the outriggers and topped up the inside of the chassis, nooks and crannies around the crossmember with Tec7 spray and Waxoyl.
It is over a year since I plastered everything with my home - made mixture of Hammerite underbody seal and Tec7 and no rust has appeared except the bits I missed first time round.
I'm beginning to think that salt is the main culprit for rust. Where I live the roads hardly ever get gritted in Winter whereas my father-in- law's 90 (London) which is only a year older than mine is well rusty underneath
Post #168410 14th Sep 2012 5:27pm
took the top rail off my hannibal rack and fitted the rack onto the 110 - and it fits into the garage - yea!
40" Rigid Industries LED Bar fitted this morning, off to the plains tonight to try it out - photos to follow Thumbs Up
Post #168452 14th Sep 2012 8:28pm
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
Well, today we 'put away' the last bits of summer, marked by the removal of the roof tent. The tent has only gone on once, put up there by 4 blokes at Trek Overland's place when they fitted it.
With only 2 of us at home to take the tent off it was a bit of thinking then a cunning plan was formed and put into operation.....
1. Parking the 90 near side on to the front of the 100", about 5m away.
2. Taking the bolts out of the sliders on bottom of the tent, loosening the universal mounts off, taking out other bolts and spacers as required.
3. Putting a strap from the roll cage near side, towards the front of the tent, down to one side of the tubular bumper of 100"
4. Putting another strap from the roll cage near side, towards back of the tent, then shackling that to payed out winch rope from the front winch on the 100"
5. Then Reversing the 100" to adjust tension on the two straps to form a sloping 'slide' from the top of the roll cage down towards the bumper of the 100"
6. Lifting the roof tent up a bit, removing the mounts, and sticking a few bits of thick card underneath to protect the top of the cage from being scratched and to reduce effort required to move it.
7. Placing a B&D Workmate bench under the 'slide' at about waist height
8. Pushing the tent from the off-side towards the near side, until it started to pivot over the edge of the top cage bars, steadying as necessary.
9. Gradually pushing the tent 'over the edge until fully on the 'slide' and gently lowering down until it sits on the workbench.
10. Stage 1 complete
11. From waist height, turning the tent off the bench to sit on end and then carrying into house!
12. Placement of tent against wall in Dining Room (otherwise know as 'General Storage Facility'!).
After that, it was time to put the snorkel on! Had it made by P&P to go with the cage and it has been propped up in the aforementioned GFS since March. Anyway, as it was I 'lost' the little black plastic wing cover somewhere between Knaresborough and York last week so it was a good time to get the snorkel put on at last, if nothing else put to cover the hole in the wing!
I think it looks rather smart!
 Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #168598 15th Sep 2012 8:06pm
Glynparry25
Looks good Thumbs Up
Just as a quick note though........ Check the inside of the snorkel. When I got one from P&P it was full of swarf from the manufacturing process...... and the inside wasn't painted at allI like to think mine was the only one..... but best safe than sorry.
Glyn Dog Sheep
Post #168599 15th Sep 2012 8:16pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
That's on my list to do, when we did a week in the new forest all the barriers to the car parks stopped us be the side rail on the hannibal Thumbs Up
Did move the DC 4ft back today then 4ft forward today so to replace dog crate in Motorhome then repacked everything It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #168601 15th Sep 2012 8:26pm
oh yes Thumbs Up - bright does not come close, took it over the plains (only place where there's no traffic), can see for miles
Post #168608 15th Sep 2012 8:49pm
