Home > Technical > Early Series Type Doors on Defender
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
I have a couple of questions which will be really simple for someone in the know.
I'm planning on moving to this style of door to give me more space (and because I like the look) and I want to make sure I get the right thing.
Is the door lock (Drivers Side) the same as that on the rear door? I have read about Antiburst locks but i'm not really sure what these are exactly and if that is the try I need. Etc
Any guidance?
Post #167303 10th Sep 2012 9:57am
T1G UP
not sure on the space issue as they fill the same hole in the same way!
the anti burst things to stop the door opening whe you hit a bump http://www.paddockspares.com/2006abr-door-...icles.html
its the tops that are expensive as you'd be best to get the ali double slders.
Post #167305 10th Sep 2012 10:03am
Tig up - You get more elbow room as there is no door card / wind down window
I used the rear door lock as the drivers side one on my Trayback
Post #167307 10th Sep 2012 10:19am
me@td5.org
I'm happy to pay for some good door tops as the comparative cost to new wind up window doors is huge.
I am weighing up whether to go for Ashtree Galv bottoms with Rock Mountain tops or if I should get the whole lot from Rocky Mountain.
Post #167324 10th Sep 2012 11:22am
I have a pair of Rocky Mountain tops that I picked up on Ebay - very please with the quality - I haven't seen the Ashtree ones I'm afraid so can't comment - HTH
Post #167328 10th Sep 2012 11:25am
The drivers side lock unit isn't the same as the rear end safari door... I've just fitted a pair to the project90 i've got (using military split doors)
Although with some grinding/cutting, I suspect that the rear catch (not the lock that's on the door, but the cast iron bit that bolts to the bodywork frame) could be suitably bodgified to work on the front door.
Although for what they cost even new, I'd be inclined to use the proper one seeing as that is what stops you from falling out.
Post #167368 10th Sep 2012 2:27pm
me@td5.org
That is useful to know. I have no problem which buying the right thing. I just want to make sure I can set them all up with the same key!
Post #167370 10th Sep 2012 2:35pm
I'm sorry, I thought you were talking about the 'keep', the bit that stays on the vehicle, not on the door - they are the same as the rear door and people use those because drivers side ones seem scarce for some reason
Post #167371 10th Sep 2012 2:39pm
They're not the same. they are interchangeable, like I said, with some bodgification., but not the same... the rear one has the rubber buffer thing on it to stop the door from vibrating.
Post #167428 10th Sep 2012 4:46pm
Am I at least right that they are used because you can't get the drivers side originals Bow down
Post #167430 10th Sep 2012 4:49pm
me@td5.org
I hadn't realised that the strikers were different either! Just as well I didn't buy a pair of X-Trousers at the weekend!
Are the hole centres the same?
Post #167463 10th Sep 2012 6:33pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
Phil , our kid has just done it with his USW, if you have a look on my FB page, i've commented on it so you should see what it looks like... Putting Dreams on Drives at JLR Solihull..
Post #167465 10th Sep 2012 6:37pm
me@td5.org
Cheers Ada, is there anyone in your Family that doesn't have a Landy?
Post #167469 10th Sep 2012 6:44pm
adafish
errrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr.....NO ! Putting Dreams on Drives at JLR Solihull..
Post #167472 10th Sep 2012 7:04pm
