Home > Technical > Bluetooth OBD Reader |
SimonR Member Since: 28 Jun 2012 Location: Horsham, West Sussex Posts: 74 |
Matt, keep us posted on whether it works on iPhone!
Si |
3rd Sep 2012 4:31pm |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
I wouldn't recommend a garage outfit using these, but for the occasional user, thats 20x £10 ones for the same price. Can't see going through 20 of them in my lifetime. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
3rd Sep 2012 4:37pm |
DarrenJ Member Since: 07 May 2012 Location: North Beds Posts: 312 |
Defo let us know if works on the iPhone, if it does it's another one ordered! Darren
3rd Sep 2012 6:22pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
i just ordered one
3rd Sep 2012 7:35pm |
amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452 |
This looks great but I have an older 1999 td5 I'm guessing it won't work with that?
3rd Sep 2012 8:03pm |
Not sure that your's will be OBD2, if not, it won't work unfortunatly. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
4th Sep 2012 8:10am |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 |
It won't work for any live data from the TD5, the standard codes may be able to be read but that is it.
5th Sep 2012 8:08pm |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
the wifi ones work better with iphone (unless you have a jailbroken one) as the iphone bluetooth is very restricted.
6th Sep 2012 5:45pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17202 |
Mine arrived today but I don't seem to be able to connect to it.
I am using an HTC phone and torque pro on an 07 Puma. With the interface device in the socket and the ignition on, I get a "paired but not connected" status from the Bluetooth manager and torque says that it isn't connected to the OBDII device. Nothing I do seems to make a working connection. Any ideas anyone? Faulty device? Faulty socket? I did try it also on my 02 Td5 Disco knowing it may not work but thinking it should at least power the device and allow pairing but it is exactly the same as on the Puma. Any help gratefully received, thanks. |
6th Sep 2012 7:14pm |
Ok, cancel the SOS! Just fiddled about some more and it's started working. I didn't do anything different and I suspect it may have been caused by a poor connection in the socket or something like that.
A great little tool for £13 or so! |
6th Sep 2012 7:47pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2623 |
I had the same issue. You must go into Torque > Settings > Device and then select the device, which must already be paired with your phone. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
7th Sep 2012 11:11am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Did anyone get it working on a TD5? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
21st Sep 2012 3:11pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
No, not me....I looked on the interweb, but couldn't find any evidence it would work....
Cheers Simon |
21st Sep 2012 3:16pm |
Yeah, the Td5 is a funny one. AFAIK, only the Hawkeye and Nanocom work with it. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
21st Sep 2012 3:55pm |
