Home > Puma (Tdci) > gear lever vibration
deanbeeley
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
ive got a real fu--ing annoying vibration for the base of the gear leaver at low
revs. clutch been replaced recently but did it before, any ideas?
Post #165008 28th Aug 2012 10:43pm
Killer90
Site Sponsor
common problem on a puma last time i come across it it was the lower part of which the gearstick goes into Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #165009 28th Aug 2012 10:46pm
deanbeeley
pretty sure is the lower part as if you hold the gater it stops
what part is it and does it mean gearbox out?
Post #165015 28th Aug 2012 11:01pm
Killer90
Site Sponsor
TSC500020 thats the part number its around �70 Thumbs Up i would have thought you would have had to lift the gearbox tunnel out but its only held in with screws pull your carpet or matting up and youll see what i mean Very Happy that part number is the whole thing they only list one part to replace CSK Automotive
Post #165019 28th Aug 2012 11:52pm
I had this back in the winter time although in high gears 5th and sixth. Really annoyed me too but it went in a couple of months without being touched Thumbs Up WeWillWin🇬🇧🇺🇸
Post #165022 29th Aug 2012 12:02am
AlpenAndes
Austria 2010 Defender 110 Puma 2.4 SW Belize Green
Re: gear lever vibration
you say you haev a vibration at low revs, I got the gear lever swinging some 2cm left and right between 2000 and 3000. Just putting one finger slight on top of it it stops. Any idea what that can be?
BR
Oskar
Post #165030 29th Aug 2012 5:09am
yorky
England 2007 Defender 90 Puma 2.4 SW Java Black
mines the same, presumed it was pretty normal in a Defender? Finger on stops it so I feel its normal vibration with a Puma diesel. 90 XS
Volvo V70
Post #165105 29th Aug 2012 3:22pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Check this thread. On mine I had a gear stick vibration when the gearbox was warm, stopped by gentle pressure on the base of the gear stick. Tightened up the weights and no problems over past 20,000 miles.
[url] http://www.defender2.net/forum/topic6478.h...tion[/url] LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #165132 29th Aug 2012 6:00pm
deanbeeley
thanks for all the info
just took gearlever out and the weights were loose
tightened using super glue
hey no vibration
Dean Very Happy Very Happy
Post #165162 29th Aug 2012 7:54pm
AlpenAndes
Thanks, for the tip. Will try that once I get my car back from the stealer here behind the Andes sitll trying to fix the heating and other warranty stuff already for a month...
BR
Oskar
Post #165167 29th Aug 2012 8:14pm
WelshGas
I used nylon cable ties to fix the loose weights. Worked so far. Thumbs Up LANDYWATCH
Post #165197 29th Aug 2012 9:27pm
CyberCharlie
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
I have slipped some thin cardboard pieces behind the weights. No more vibrations.
Post #165265 30th Aug 2012 9:13am
