Home > Wheels & Tyres > Mantec Spare wheel carrier
Page 2 of 2 <12
I think SEB's monitor has fallen over Rolling with laughter
Post #163391 21st Aug 2012 7:06am
ickle
SS - I fitted them above the steel washer, in the pivot of the brackets.
Also make sure that the piston mount is tight.
The plastic washer can make the rear door stiff to open, but it does stay open.
I'll be at Eastnor if you're going and want a looksie.
Keith
Post #163577 21st Aug 2012 9:30pm
superspoons
England 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Thanks Keith,
Won't be up at Eastnor as other plans unfortunately.
So, you've fitted them between the steel washer and the nylon inserts of the arms, tops and bottom mounts? Cheers,
Superspoons
Post #163780 22nd Aug 2012 7:03pm
ickle
Hi SS,
Yes that's correct. I used some flat plastic sheet, I think it was the side of a 25l used oil container IIRC and a hole saw, not knocked since.
Good luck!
Keith
Post #163852 22nd Aug 2012 10:13pm
dgardel wrote:
is that a genuine LR rear step? It would be good to kno mantec carrier is compatible.
Post #176603 17th Oct 2012 7:48pm
K9F
Supacat....
Quick search reveals: Swing away carrier this post....Step next post.... Thumbs Up
dgardel wrote:
Yes, I have the Mantec one and the lower part is fixed to the rear crossmember. great piece of kit, I'm happy with it (my rear door also) Thumbs Up
http://www.defender2.net/forum/topic11916....=rear+step If you go through life with your head in the sand....all people will see is an ar5e!!
Post #176606 17th Oct 2012 7:52pm
mk1collector
Supacat wrote:
Hi I think it's a genuine nas rear step
Ray
Post #176620 17th Oct 2012 8:15pm
K9F
mk1collector wrote:
Hi I think it's a genuine nas rear step Ray
***Edit....****
Dgardel's rear step.....
dgardel wrote:
I bought mine here
http://www.lrseries.com/shop/product/listi...amp;page=1
Post #176623 17th Oct 2012 8:19pm
Seems to be a different part number for genuine or non-genuine and then part numbers are different again for 90 or 110...
Post #176634 17th Oct 2012 8:41pm
K9F
Supacat,
Sorry just noticed yours is a 110. Obviously the genuine will be more expensive (by £100) but if it has the same mounting arrangements one would assume it would be compatable with the Mantec wheel carrier. Knowing Dgardel as we do nothing less than genuine would have sufficed. Maybe give him a 'pm' and phone the company perhaps to ensure you get what you require?
http://www.lrseries.com/shop/product/listi...earch=rear step&page=1 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #176635 17th Oct 2012 8:47pm
Page 2 of 2 <12
