![]() | Home > Wheels & Tyres > Mantec Spare wheel carrier |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 617 ![]() ![]() ![]() |
Pretty easy really, fitted one to my truck last January, see the last couple of photos in this thread:
http://www.defender2.net/forum/topic11080.html |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
Been thinking of one, but they are expensive for what they are. Cheaper ones around sold by Paddock, for example. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
jont Member Since: 02 Apr 2011 Location: Aylesbury, Bucks Posts: 242 ![]() ![]() |
Had one fitted by pete and lewis from flatdog at billing yesterday and watched them do it ...
key points are remove door card carefully to avoid breaking the retaining clips ... gentle drilling out of the two left hand rivets in two stages ... check fit of mounting plate by offering up the bolts and plate from the outside first ... don't tighten the bolts on the lower hanger plate as you might need to ease the arm in to fit ... metal washers on the top of the top mount and the bottom of the bottom mount ... and piston mounting plate is offset so shorter side goes to the left/handle side of teh door other than that it's probably a 45 min job rgds Jon |
superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314 ![]() ![]() ![]() |
Thanks all for your replies.
Will do it this week and may post up a 'How to..." with pics if people think it's worth it?? Cheers, Superspoons |
Like lots of things there are always cheaper options but are they as good? A few things to consider. Are grease nipples fitted as standard? What size are the brackets? Reinforcing brackets? Where do the brackets mount? i.e. will they interfere with rear bumperette/NAS step fitment? Brendan |
Fitted mine today. No real issues although Mantec's instructions need updating... minor points really. Only 1 rivet to drill out on the upper mount on mine and one new hole to drill. Plus the fitting plate on the door has bolts already on it. Took me about 2hours in total as I wanted to get it right.
![]() Click image to enlarge Cheers, Superspoons |
Was there a reason for the metal washer being on top of the top mount as the instructions show it as underneath? ![]() Click image to enlarge My install below. Top mount - ![]() Click image to enlarge Bottom mount - ![]() Click image to enlarge Cheers, Superspoons |
I installed my mantec in that way! ![]() ![]() IID Pro MV License |
Thanks.
![]() Just to confirm that the white poly inserts are located the same way too (mine were loose in the packaging after falling out during transportation). I need to adjust it a little, as despite spending ages lining it all up I have a noticeable banging noise from the back. Can't see anything loose but will look closer when I have time. Cheers, Superspoons |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1849 ![]() ![]() ![]() |
mine knocked as well, I made up some round plastic shims to take up the play and its been silenced for over a year now...
Keith |
Keith,
Thanks, but where did you fit the shims? On the main mounting bolts or the piston? Cheers, Superspoons |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Superspoons, shims are the least of your worries - someone's tipped your Defender onto its side ![]() |
OK...you've got me... what are you talking about ![]() Superspoons |
