Home > Puma (Tdci) > hand brake |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 |
I get this, not when its been raining though, but usually the morning after I've given it a good going over underneath with the pressure washer - it's almost as though the handbrake is sticking on. Never need to give it any revs though, just lift the clutch slightly.
To be honest I'm not sure if I need to be concerned or not, it's something that I only tend to remember about when it happens, usually it's left in gear on the flat after I've washed it, only when I park it on a slope afterwards I notice it. I wouldn't like to say 100% it's normal though, but your not the only one! I'm sure someone will be along to give a proper answer |
16th Aug 2012 9:12pm |
boxer Member Since: 12 Jun 2011 Location: north yorkshire Posts: 48 |
Thanks for that, just worries me incase i damage anything driving off when they are stuck on.
16th Aug 2012 9:20pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
If the handbrake shoes are wet or damp when the brake is applied for any length of time there can be a tendency to for them to stick to the drum, this can also get worse if there is any oil contamination or a lot of brake dust. You are putting a fair amount of strain on the transmission by driving against a locked brake so it would be an idea to pull the drum back for a check either DIY or at a dealer / independent. Steve.
17th Aug 2012 9:28am |
