Home > Maintenance & Modifications > Choosing Roll Cages |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17388 |
Glyn, with the help of your photos the mystery is solved!
I noticed comparing your pics to my Defender that the passenger side was the same as yours but on the driver's side the 'wing' of the seat was further back than it should be and the seat was 1.5" wider. I took the fabric skin off the seat back (much easier than I expected) and found that the shaped foam inner had split on the side near the door where it fits over the armature of the seat. This had pushed it sideways and allowed it to slip backwards. It also explains why every now and then my right hip would meet something very solid inside the seat - the exposed frame! Since my seats aren't heated I have repaired the foam with a generous application of "black nasty", refitted the fabric, and now not only is there room for the hoop but the seat's more comfortable too! So please accept my thanks! |
2nd Aug 2012 7:39pm |
Appleby Member Since: 03 Apr 2012 Location: Bristol Posts: 74 |
just a quick question not really worth its own thread. Has anyone ever had a 60th anniversary style cage made up?
I fancy going soft top (in the future not soon!) and I think a 60th style roll cage would be awesome in black. Anyone seen one? Ta |
7th Aug 2012 1:27pm |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
Protection and performance do one, have done since the svx came out Russell
2011MY 110 XS USW Black |
7th Aug 2012 1:46pm |
Glynparry25 - did you consider putting any rollcage padding on the internal tubes? It would be maddness to survive being crushed in a rollover only to crack your skull open on the tube.
25th Oct 2012 12:40pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
I have been tempted to several times.... but never get around to it ........ Plus I doubt it would do much damage anyhow -
Click image to enlarge Glyn |
25th Oct 2012 12:58pm |
Arierep Member Since: 12 Apr 2013 Location: Portugal Posts: 258 |
Resurrecting this thread to avoid starting a new one.
This week I placed an order for a Safety Devices L148 roll cage. Is the Camel Trophy one but compatible with rear bench seats on the 90. However, I'm having some second thoughts after seeing so many full external cages. Anyone can comments the pluses and minus of each type? I want to add a roof rack. With the L148 I'l just get a Brownchurch type to complete the Camel look. Everyone says that attaching the rack to the full external cage is the bees knees but I'm yet to see that with a rack that goes the full length of the roof or doesn't costs an arm and a leg. Any comments? |
7th Feb 2016 6:44pm |
Bumpymike Member Since: 18 Nov 2015 Location: cheshire Posts: 71 |
I was down Merzouga in Morocco and a german registered 90 soft top with an external cage was turning right and didn't get out of the way fast enough and an old Mercedes lorry clipped the rear corner and rear body caught the cage ...rear corner wasn't too bad and xmember straight but it pushed the whole cage forward - destroying the back body and front wings- it went back to Germany on a trailer it was so bad.
In that case a Camel cage would of been better. |
10th Feb 2016 2:01pm |
Les Brock Member Since: 20 Mar 2012 Location: Stroud, Glos Posts: 151 |
Safety devices external on my shed.
Click image to enlarge Click image to enlarge Click image to enlarge No problems fittings either |
10th Feb 2016 3:46pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10382 |
I've read your build thread on another site...with much admiration. Then when you fitted challenge wings, I wept
10th Feb 2016 5:28pm |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
that's a nice suspension set up, also liking the fuel filler location. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
10th Feb 2016 5:34pm |
I know what you mean, they might well be off this summer |
10th Feb 2016 7:24pm |
I'm sure it will transform it.
Much respect for the build and finishing it, the ups and downs, deciding if you're going to keep it etc. As I'm 80% done on mine I appreciate what went into yours |
10th Feb 2016 7:51pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
I have the L148 type cage, and I wish I'd got the full external cage. I use my 90 for green laning and I've bashed the rear sides and roof a few times, which a full cage would have protected. A full cage would also give me extra options for storing waffle boards and roof rack fitting. Cheers Simon |
10th Feb 2016 8:02pm |
Edzi Member Since: 20 Sep 2015 Location: London Posts: 279 |
Hi Les,
Might you have any pictures from inside? Intrigued to see if any of the cage is internal as well? Thanks, Edzi |
10th Feb 2016 8:35pm |
