Home > Maintenance & Modifications > Scangauge II code clearing abilites... "no response&quo
Molusk
France 2008 Defender 130 Puma 2.4 HCPU Alpine White
Hello,
yesterday I drove my puma with EGR disconnected, and of course after the 3rd switch-on the MIL occured.
According to my Scangauge II fuel consumption measurement, it seems that I improved my MPG, but I did not feel any difference in the driving.
So I now decided to plug back the EGR and to switch off the MIL, using the Scangauge. The scan shows me 2 errors, but when I press the clear button, it displays "no response".
-->what does that mean? Is it normal?
Another question: is there any drawback driving with EGR disconnected? Is there a risk to have the ECM switching to degraded mode?
Thanks for help,
julien.
Post #157404 23rd Jul 2012 7:44am
K9F
Lorryman is the person you need advice from...Drop him a 'pm.' Thumbs Up
Driving with a MIL light constantly on due to a disconnected EGR would drive me nuts...Also you could potentially mask a more serious issue as you would not know whether another fault has been thrown up. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #157428 23rd Jul 2012 11:14am
Molusk
screening this forum, I found an advice from Lorryman in another topic, saying the best moment to clear the DTC codes is when the engine has just shut down. I guess it is a voltage issue, but it worked! Thumbs Up
Post #157546 23rd Jul 2012 8:33pm
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
the engine has to be off but the ignition on to clear the codes.
Post #157954 25th Jul 2012 6:37pm
Lorryman100
Cheers for the confidence Mal, an email would be a better form of contact though. Whistle Thumbs Up
Brian
Post #158020 26th Jul 2012 12:17am
Lorryman100
Re: Scangauge II code clearing abilites... "no response
Molusk wrote:
Hello,
Thanks for help,
julien.
Glad you got it sorted Thumbs Up
If the scangauge doesn't allow you to clear a dtc you can always do a hard reset. Disconnect the earth lead off the battery and press the brake a couple of times to discharge any stored capacitance. Then after 10mins reconnect, then switch on ignition and clear the dtc's. Or you can disconnect both terminal leads and touch them together, personally I prefer the first option. Whistle
Brian.
Post #158023 26th Jul 2012 12:24am
Molusk
Brian.
Thanks Brian for this advice Wink
Julien.
Post #158029 26th Jul 2012 6:42am
