Home > Td5 > I have a new noise to report....
Gareth
I hear a pretty loud 'crack' or 'pop' from the rear if I lift off, or reapply the accelerator with anything less than smoothness.
A rough or sudden reversal of the accelerate/decelerate momentum will induce the noise. It only does once in each direction. By that I mean if I set off fast from traffic lights, it will make the noise. If I decelerate gently, then repeat the fast start it will NOT make the noise. If I accelerate gently it will not make the noise, but if I lift off the accelerator suddenly, it will. Then it will do it on the next acceleration. So whatever it is, its not something very loose, it obviously takes some force to move it and make the noise.
It was only doing it very occasionally until recently, now its got much more frequent.
I hope you understand this, its quite hard to describe! 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #157422 23rd Jul 2012 10:05am
Laurie
Sounds like A frame ball joint.
Also, check radius arm bushes.
Post #157423 23rd Jul 2012 10:38am
Gareth
Thanks for that. I have tried to lever the radius arm bushes with a jemmy bar and the only movement is in the rubber flexing, so A frame joint seems like the culprit.
Is it normal practice to replace the whole A complete with ball joint and pivot bushes? or will it just be the ball joint itself that's worn?
Car has only done 50k miles, 52 plate. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #157450 23rd Jul 2012 1:38pm
Probably the ball joint, get a jemmy on that too.....
Check your UJ's too (not with the jemmy) Laughing
Post #157459 23rd Jul 2012 2:12pm
landy andy
Could also be drive flanges, or pinion wearing on the splines if not the ball joint, or prop uj's.
Andy
Post #157553 23rd Jul 2012 8:41pm
ashtrans
Site Sponsor
I would say it's the diff drive flange rocking on the splines and 'cracking' under load
there is a recall on this which goes along the lines of remove prop, bolt and flange, cover pinion spline in loctite, do bolt up bloody tight !
Dave Dave
Post #159164 1st Aug 2012 4:03pm
