Home > Technical > Electric window
Page 3 of 5 <12345>
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
It was quite strange...shut window went in shop....got back in truck went to open window nothing NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #157353 22nd Jul 2012 7:55pm
Hmmmm, Wonder if the mech is gone it's really hard too tell. A multimeter should tell all electrically speaking other than that it's only mechanical that could have gone wrong which is un-likely. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #157354 22nd Jul 2012 7:58pm
fekete
I'll get it tested and let you all know the outcome Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #157356 22nd Jul 2012 7:59pm
Good luck Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #157357 22nd Jul 2012 8:00pm
JSG
Where abouts are you fekete? I can have a look for you if you aren't too far away. John
2011 Tdci 110 CSW XS
Post #157502 23rd Jul 2012 5:31pm
fekete
Mr. Green Mr. Green Right guys, all you that said it would be a broken wire was spot on Bow down i cut the rubber sleeve and the red was Broken in half and the blue was on its way..... thanks to everyone for your help and advice it was spot on..
Cheers for the kind offer JSG Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #157523 23rd Jul 2012 7:03pm
great news Mr. Green TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #157532 23rd Jul 2012 7:28pm
K9F
Glad it's sorted for you Karlos. Thumbs Up Nice result...... If you go through life with your head in the sand....all people will see is an ar5e!!
Post #157544 23rd Jul 2012 8:22pm
fekete
Guys i was getting a bit fed up with not having a open window it was getting hot in there......i was so relieved when it worked once again thank to all Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #157549 23rd Jul 2012 8:34pm
Zim
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Stornoway Grey
THIS has been a life saver of a thread.
I drove to Screwfix, wound down the drivers window on the way there and when I arrived the window would not work!
I did a search, found this thread but I did not want to cut the rubber sleeve first off, so I checked all the fuses - FINE, then I took out the dash to remove and check the switches - FINE, then I took the door card off to check the power to drivers window motor - NOT FINE.
Finally I relented and cut the rubber sleeve and hey presto, and broken red wire and partially broken blue wire!
Many thanks! Bow down 2007 Defender 90 XS
2022 Defender D300 HSE X-Dynamic
Post #359087 20th Sep 2014 2:28pm
WendyTheTruck
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
The drivers side window stopped working on mine this week also. Assuming it is the wore broken in the A pillar to door conduit, what is the recommended best way to prepare (other than stripping the complete wire from the harness and replacing), solder crimps and heatshrink Question
Post #396655 7th Feb 2015 12:33pm
landy andy
You don't need to cut the rubber boot. I just unclip it from each end and pull it back and forth to find broken wire. Then cut wire and strip, solder in new good quality wire with heat shrink over joints. I extend wire, so that both joints are hidden, one in A post other in door, so joint does not get flexed.
Andy.
Post #396665 7th Feb 2015 1:16pm
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
I should also mention that I had a non working window but all the fuses, switches and wires checked out ok. It was a sticky mechanism stopping it. After greasing and lubing it all, it works fine. I also then removed other door card and lubed it to prevent a future problem. It cost nothing except a bit of my time, some new card clips and gaffer tape to repair the damp membrane. (I think it is easier to cut and repair the membrane than remove it and deal with all their sticky chewing gum stuff)
Post #400223 19th Feb 2015 7:40am
chiversn
Great thread - mine stopped working suddenly yesterday (is it always a hot afternoon when it happens? Very Happy )
Anyway, fuses are ok, but a wire has broken inside the rubber sleeve - got one end exposed, but the other end is inside the sleeve somewhere - do I really need to cut the rubber sleeve to get at it?
If I pull out the rubber sleeve of the door card (door card remaining on ideally - having repaired the door card clips in the past) will it go back in ok, afterwards?!
Thanks in advance. ----------------------------------------------------------------------------------------------
My first job involved driving from Southampton to Wick in a 300TDI (twice)
The experience of 3000 miles in a Defender has never left me (for many reasons!)
Post #433543 25th Jun 2015 9:36am
K9F
Chivers no need to cut, you can tape the end of the replacement cable to a long screwdriver and gently manipulte the new cable through the rubber boot umbilical and then terminate/splice the new cable to the old and then pull it back through the boot again so the repair is in the boot. Or you can terminate/splice the new cable in outside each end of the boot. When I sorted Rustyboxx's I used the end of a fibreglass cable rod to pull through but then again I'm a sparky and have them at home. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #433550 25th Jun 2015 10:14am
Page 3 of 5 <12345>
