Home > Technical > Electric window
Page 4 of 5 <12345>
Spartan
K9F
I did just as you suggested and eventually found the red wire inside the rubber hose cut. I was ready to order a new window regulator so by searching this forum I saved a lot of time and money.
All is good. My window has been unusable for a few months.
Thanks
Post #441813 31st Jul 2015 1:17am
K9F
Good news, glad you found the information you needed and sorted it! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #441850 31st Jul 2015 8:42am
ECH241
England 2008 Defender 110 Puma 2.4 USW Java Black
Hi woundered if any one could help??... My drivers side electric window won't work I have checked the fuse and it was blown so swapped it for another (new 20amp) and this also blew?? Any help would be great thanks
Post #500642 4th Feb 2016 10:36pm
JWL
I'd be looking at the bunch of wires that go from the door pillar to the door itself. These are prone to breaking inside the rubber sheath, it's highly likely that the wire/s have broken and earthing out causing the fuse to blow.
Post #500644 4th Feb 2016 10:48pm
ECH241
Ok brilliant I will check in the morning and let you no....might b asking for a bit more help yet thanks
Post #500646 4th Feb 2016 10:51pm
ECH241
Spot on jwl it was just like u said cheers
Post #500983 5th Feb 2016 8:36pm
Mike T
South Africa 2008 Defender 110 Puma 2.4 SW Blenheim Silver
Hey Guys, This thread was a lifesaver. Right drivers electric window stopped working...checked fuses and relay, all good. Then stripped the door down and found the green cable sheared off. Re-soldered, extended and all back to normal in under an hour. Thanks Boys
Post #525712 21st Apr 2016 11:47am
edalelr
I have a slight variation on this problem... on both sides the electric windows have become increasingly difficult to open, requiring a lot of pressing of the switches to get anything to happen. This started on the drivers side, which got progressively worse, then started on the passenger side. Now almost impossible to open either side. The weird thing is that the whole time, even now, they close absolutely perfectly.
Could this still be a switch problem or the usual issue with broken wires at the door pillar? Or is it more likely to be something to do with the actual winding mechanisms? I would have thought the latter if it wasn't happening on both sides.
Any advice much appreciated!
Thanks!
Post #585455 15th Dec 2016 11:02pm
mactheknife
United Kingdom 2004 Defender 110 2.5 TD CSW Baltic Blue
Just used this thread to find the problem with my drivers window. Hottest day of the year, defender boiling inside after being in the sun all day and an hours drive home with no ac or opening window!.
Checked the fuses, swapped the switches. Still no fix. Quick Google and I arrived here. 2 mins later I find a broken wire in the door loom! Thanks for all the responses on here, well done.
Post #621183 2nd May 2017 11:03pm
Djcla
I have this issue now Sad checked wires in rubber tube between door and Pilar as best I could the seem to be intact. Where are the fuses located as I'll start from there I guess. Can you get to and swap the switches from the stereo gap btw?
Post #680679 22nd Jan 2018 10:26am
Djcla
In trying to shift the rubber sleeve back I found a broken red wire Sad. Struggling to get the sleeve to pull back though and really don't want to cut it.
Post #681002 23rd Jan 2018 10:30am
Djcla
managed to repair this by feeding through some new higher spec wire through the conduit and making the new joins . Electric window works again, for now at least anyway Smile
Post #682563 29th Jan 2018 10:56am
russfish
England 2010 Defender 110 Puma 2.4 DCPU Indus Silver
Driver electric window fixed
This was a great thread, thank you chaps.
After testing the fuses, swapping the switches (as passenger side window worked fine) then looked at the rubber conduit between car and door, eventually found the culprits, both wires blue and red were broken half wa along inside the conduit.
As pointed out earlier in this thread, this wire does seem to be particularly stiffer, therefore less flexible and I imagine prone to breaking. I threaded some rubber encased outdoor wires through the original conduit and crimped the joins. All the older wire is now either in the pillar or in the door, so won’t be moved resulting in breakage.
I guess I’ll just wait until I have to do it again on the passenger door side!
Thank you again guys - really useful.
Post #685076 8th Feb 2018 7:03pm
that man
England 2012 Defender 90 Puma 2.2 HT Corris Grey
Brilliant boys right first time broken raed wire in the flexi rubber fixed sorted BRILL Many thanks --- that man Thumbs Up
Post #690707 3rd Mar 2018 11:06pm
Leeroy
United Kingdom 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
Thanks guys mine gave up today in this
weather
Post #694110 17th Mar 2018 7:27pm
Page 4 of 5 <12345>
