Home > Puma (Tdci) > Fitting an Entreq rear load sill
jerseyman
I'm fitting an Entreq load sill to my 90 Defender. All straightforward except that I am not sure what the the nylon washers are for. Presumably to isolate the SS from the ali? But that is already done by the lower door seal? - at least it is once I dug all of the embedded swarf out of it.
So does anyone know what these nylon washers are for?
Post #155403 13th Jul 2012 3:23pm
I could be wrong but on top of what you mention about isolating the SS from the Alu. It may also be to stop the holes being pulled in too much when the screws are tightened down. If you know what I mean. Thumbs Up WeWillWin🇬🇧🇺🇸
Post #155405 13th Jul 2012 3:28pm
VeeTee
Netherlands
Right. They are to make flat install, to adjust space insert under the SS. See their installation manual, rather in German: http://www.entreq.de/media/uploads/Montage...eisten.pdf Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #155409 13th Jul 2012 3:38pm
I thought that might be the reason why. Thumbs Up Would look pretty naff otherwise. WeWillWin🇬🇧🇺🇸
Post #155413 13th Jul 2012 3:42pm
jerseyman
Thanks guys, The PDF refers to the side door sills whereas I'm fitting the rear door seals - that's my next job so expect another post.....
The rear sill seems to have fitted evenly without the nylon washers so i will leave it at is I think
Post #155417 13th Jul 2012 4:14pm
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
entreq stainless rear door strip
I also was wondering when I replaced mine.
I eventually left them out and in order to be safe re: cathodic corrosion I applied a smidging of 'Duralac' to the original drilled screw holes. Todate no corrosion Wink
'El pepe flamenco' JLS
'El Pepe Flamenco'
Post #155546 14th Jul 2012 3:46pm
