Home > Puma (Tdci) > 3 beeps ? |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 |
3 beeps....
In our case, happens when you press the door lock/alarm system button in the remote comand and one door is open. Maybe you pressed the door lock button accidentally Sorry for my ingnorance, but what means RWW? I hope that can help you. Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
15th Sep 2009 7:51pm |
Pob Member Since: 23 Jan 2009 Location: Midlands Posts: 119 |
rear wash wipe 110 Hard top
15th Sep 2009 8:24pm |
driver Member Since: 02 Aug 2009 Location: bude , cornwall Posts: 206 |
The remote fob works fine , the 3 bleeps are coming from the dash behind the speedo
15th Sep 2009 9:07pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2424 |
If it is at the same time everyday, then you know a factory worker left his watch Puma 110" SW
15th Sep 2009 9:56pm |
Strange indeed
The only other sounds when you turn off the motor in mine are: The radio (Sony) also makes a sound when the motor is shutdown but I dont think that woukd be the 3 beeps that you heard and some kind of sound produced by a piece that continue the rotation but do not seems to be that also. Try to close the car with the FOV with an open door Is it the same beep or another different? You heard it only one time or is recurrent? Maybe can comming from other car in the parking lot. Anyway, better ask to the dealers. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
15th Sep 2009 10:15pm |
peanutbob Member Since: 12 Feb 2009 Location: UK Posts: 293 |
It's the new government rules I'm afraid.. 3 beeps and you're not allowed out. It will also disable the RWW (LR/LBGFO)
15th Sep 2009 10:16pm |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
Do you mean a beep like the low fuel warning beep?
Never heard 3 beeps myself. The horn does sound if you try to lock the car with the fob and a door is still open. |
15th Sep 2009 10:25pm |
solmanic Member Since: 16 Aug 2007 Location: Brisbane Posts: 191 |
Have you got an aftermarket stereo with bluetooth? I know of some which beep at you when a paired bluetooth device is or isn't in range when it's supposed to be and the unit is switched on or off. 2007 Defender 110
1970 Alfa Romeo 1750GTV |
15th Sep 2009 11:33pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
Empty washer bottle alert 2.4 90 XS
16th Sep 2009 3:33pm |
expedition Member Since: 11 Sep 2009 Location: Vercelli-ITALY Posts: 75 |
It's real ? Vale 110 Td4 MY07 "E" Keswick Green |
16th Sep 2009 3:35pm |
1 beep 1/3 empty 2 beep 2/3 empty 3 beep you deaf it's empty. Only kidding not sure what it is,but I bet you checked the washer bottle 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
16th Sep 2009 3:38pm |
Spoke to Landrover today re 3 bleeps, there reply was
Q by any chance have you fitted an aftermarket stereo A, yes Q Is it a SONY unit A, how did the know that ? A, from landrover its the sony headset bleeping 3 times to remind you to remove the faciea for security panic over ,visions of trips to dealer, big bills to be connected to testbook. SO IF YOU FIT A NEW SONY HEADSET THE BLEEPS WILL SOUND LIKE THERE COMING FROM BEHIND THE SPEEDO DONT WORRY !!!!!!!!!!!!!!!!! |
16th Sep 2009 8:32pm |
16th Sep 2009 9:02pm |
OK, same as my Sony radio. Good to know that the "bleep's mistery" were solved Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
16th Sep 2009 10:50pm |
