Home > Puma (Tdci) > 3 beeps ?
driver
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
3 beeps ?
Hi, Today after taking out the key car made 3 beeps at me ?, anyone have any ideas what could be causing this also noticed RWW has stopped working have checked the fuses but all ok ? ideas please
Post #15503 15th Sep 2009 8:37pm
Eduardo
3 beeps....
In our case, happens when you press the door lock/alarm system button in the remote comand and one door is open. Maybe you pressed the door lock button accidentally
Sorry for my ingnorance, but what means RWW?
I hope that can help you. Eduardo
Post #15504 15th Sep 2009 8:51pm
Pob
United Kingdom 2008 Defender 110 Puma 2.4 HT Rimini Red
rear wash wipe Wink 110 Hard top
Post #15505 15th Sep 2009 9:24pm
driver
The remote fob works fine , the 3 bleeps are coming from the dash behind the speedo
Post #15510 15th Sep 2009 10:07pm
MK
If it is at the same time everyday, then you know a factory worker left his watch Whistle Whistle Puma 110" SW
Post #15513 15th Sep 2009 10:56pm
Eduardo
Strange indeed
The only other sounds when you turn off the motor in mine are: The radio (Sony) also makes a sound when the motor is shutdown but I dont think that woukd be the 3 beeps that you heard and some kind of sound produced by a piece that continue the rotation but do not seems to be that also.
Try to close the car with the FOV with an open door Is it the same beep or another different?
You heard it only one time or is recurrent? Maybe can comming from other car in the parking lot.
Anyway, better ask to the dealers.
Cheers Eduardo
Post #15516 15th Sep 2009 11:15pm
peanutbob
It's the new government rules I'm afraid.. 3 beeps and you're not allowed out. It will also disable the RWW (LR/LBGFO)
Post #15517 15th Sep 2009 11:16pm
110SEB
Do you mean a beep like the low fuel warning beep?
Never heard 3 beeps myself. The horn does sound if you try to lock the car with the fob and a door is still open.
Post #15519 15th Sep 2009 11:25pm
solmanic
Australia 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Have you got an aftermarket stereo with bluetooth? I know of some which beep at you when a paired bluetooth device is or isn't in range when it's supposed to be and the unit is switched on or off. 2007 Defender 110
1970 Alfa Romeo 1750GTV
Post #15525 16th Sep 2009 12:33am
Grockle
Empty washer bottle alert Whistle 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #15556 16th Sep 2009 4:33pm
expedition
Italy 2007 Defender 110 Puma 2.4 SW Keswick Green
It's real ? Shocked Vale
110 Td4 MY07 "E" Keswick Green
Post #15557 16th Sep 2009 4:35pm
Grockle
expedition wrote:
It's real ? Shocked
1 beep 1/3 empty
2 beep 2/3 empty
3 beep you deaf it's empty.
Only kidding not sure what it is,but I bet you checked the washer bottle Wink 2.4 90 XS
Post #15558 16th Sep 2009 4:38pm
driver
Spoke to Landrover today re 3 bleeps, there reply was
Q by any chance have you fitted an aftermarket stereo A, yes
Q Is it a SONY unit A, how did the know that ?
A, from landrover its the sony headset bleeping 3 times to remind you to remove the faciea for security
panic over ,visions of trips to dealer, big bills to be connected to testbook.
SO IF YOU FIT A NEW SONY HEADSET THE BLEEPS WILL SOUND LIKE THERE COMING FROM BEHIND THE SPEEDO
DONT WORRY !!!!!!!!!!!!!!!!!
Post #15569 16th Sep 2009 9:32pm
dgardel
Italy
Post #15572 16th Sep 2009 10:02pm
Eduardo
OK, same as my Sony radio.
Good to know that the "bleep's mistery" were solved
Cheers! Eduardo
Post #15574 16th Sep 2009 11:50pm
