![]() | Home > Puma (Tdci) > LAND ROVER DEFENDER 2011 - USELESS OFF ROAD |
Just edited my last post with this - sorry for repeating myself
![]() Do you know at what speed the Wabco system cuts in? Might it be possible for the dealer to tweak the software of the Bosch unit? If the TC is really the only difference between your vehicles (and not anti-rollers etc.) it's obviously very significant for your driving style. It's something I never considered before as I only hear of people turning it off ![]() But shout it at them in German because life is also terrifying and confusing... |
Andrea Member Since: 02 Sep 2010 Location: South Africa Posts: 30 ![]() ![]() ![]() |
No worries mate!!
![]() Well as far as I can tell the 2 cars are identicle in every single way... Same anti roll bars same terrain same driver same everything. I did speak to LR about tweaking the response time of the TC and they reported that it is not possible. What gets to me is that the minute the car goes out of warranty they will find the problem!!!!! I'm wondering if I should talk to LR in the UK directly? Is this possible? |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
I think the speed refers to the speed of the spinning wheel, not the speed of the vehicle. When you start to lose traction you need to use more throttle to get the speed of the spinning wheel up otherwise the TC won't work. I know the normal reaction is to ease off and that effectively disables the TC. It sounds to me (and the LR dealership i suspect) as if you're just not driving to suit the vehicle. Do LR offer driver training locally to you like the LR Experience training they offer in the UK ? If so it might be worth signing up for it as the instructors there will be able to show you how best to use the vehicle. |
You have a good point with the speed of the spinning wheel but that means that on the 11 model the traction control is indeed less effective because I drive the 09 over easily. I used to work for LR experience here in SA but stopped before 2010. I bought the puma because of its superior off road ability when compared to other defenders.
I am pretty sure I'm driving it correctly without sounding bad, but even if I where to be making an error TC on the 09 makes any driver look like a seasoned professional whereas the 11 is less effective? My issue is that LR are avoiding an issue with my 11 TC and i wanted to know if anybody out there has experienced similar issues? I wish we could meet up so I could show everybody the difference. The LR guy drove both my cars on his test track at the dealer, the 09 sails over, the 11 does not!!!! |
Hey guys,
So, looks like the problem here may be sorted out. I took the car to another LR dealership. The technition met with me on SATURDAY and took the car for a drive on the track. It was clear to him that there was somthing wrong with my car so instaed of telling me everything was fine they started playing around with different Defenders and comparing. My TC seemed to be activating but was very lazy for lack of a better word, in other words it would activate, but not stop a tractionless tire from spinning completely which meant there was not sufficient drive to the other tires to move over tough obstacles. What they did was "reset" the TC?? Dont know how? They blead the ABS system and break sytem and tighened up a sweating bolt in the breaking system... Problem solved... well for now! I was told to try it again on the same obstacles, and if it didnt perform to my satisfaction I should take a video of what the car does, and they would then take it further. If I was still not satisfied they would call for and entire new ABS - TC unit!!!! That was great service. Thank you to all the blokes at Land Rover Centurion. Service with a smile, and faith restored in my shorti. |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 ![]() ![]() ![]() |
Andrea, great you have found the problem, good to know for all of us and indeed unexpected service.
Fingers crossed it is not something that comes back over time. ![]() |
Odin Member Since: 29 Apr 2011 Location: Aberdeenshire Posts: 237 ![]() ![]() ![]() |
I'm impressed that you finally found someone who knows their stuff. Finally a good result and well done for such tenacity!
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 ![]() ![]() ![]() |
Must say......
The okes from Centurion Land Rover is the best in the business! Esp. the head Defender technician Wimpie Willers! He solves most problems. |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 ![]() ![]() ![]() |
I have an MY11 Puma 110 and I have no problems.
Did the Gerotech axle twisters without any problems. The guy told me the wheel will turn 3/4 before TC will kick in - and that's what happened. So you did get some slip but only for that 3/4 turn. |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 ![]() ![]() |
I have no problems with mine either (MY11) and it is put through some heavy terrain especially when I am on anti poaching patrols and when I tow my heavy off road caravan.......initially I struggled as I came from a TD5 pre TC....had to learn to drive differently i.e. keep the accelerator steady instead of tapping off but once I got used to this I am so impressed with the TC, especially in deep Kalahari sand while towing.
I have spoken to another guy who felt the same way as Andrea and I told him that there must be something wrong with his vehicle. Glad to see it seem Andrea has proven me right with what they found regarding his problem. |
WinstonGSI Member Since: 24 Jul 2012 Location: Centurion Posts: 3 ![]() ![]() |
Bruce.
I have caught up on your threads on this forum, thanks, and this just confirms what I have said all along. My TC does not work properly. It is far too slow. I am going to pay Mr Wimpie williers from Centurion LR a visit like your friend andrea did cheers winston Defenderman |
Good luck Winston |
With all the historical bad feedback from the South African members about poor Land Rover service over there it is great to hear that you have found someone that 'knows his stuff!' Hope Land Rover SA appreciates and values 'Wimpie Williers' and what he has to offer as much as you do!
Good news! ![]() Treat every day as if it is your last....one day you will be right!! |
