Home > Off Topic > Safe cracking ...
Safe cracking ...
Just moved house and inherited a safe (3ftx2ftx2ft) ... but no key, the door is open .. anyone on here a locksmith ?
Post #152841 30th Jun 2012 8:39am
bob neville
Easy answer Steve, give your money and valuables to me and then you don't need the safe Rolling with laughter
I would suggest a security registered locksmith is the answer, for obvious reasons Thumbs Up
I know one in Yeovil if you are really stuck but I am sure there must be some around Salisbury.
2013 Defender 90 CSW - sold
Post #152858 30th Jun 2012 11:34am
Probably empty Confused No Guts, No Glory.
Post #152867 30th Jun 2012 1:06pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Probably easy to see as the "door is open" Whistle
Dj 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #152869 30th Jun 2012 1:19pm
Dj
Oh yeah ... Ooops Embarassed No Guts, No Glory.
Post #152872 30th Jun 2012 1:27pm
speedymarktd6
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Epsom Green
As the door is open you should see some screw heads or bolt heads holding the back panel onto the door if you remove this all the mechanism should be exposed with the lock undo lock nuts fixings and take the lock to a locksmith and you can have a key made for it or they might sugest a new lock and key if its a general design
Post #152902 30th Jun 2012 4:14pm
thanks Speedy .. I can see the screw heads, I'll have a go today and pop a photo up for those curious Thumbs Up
Post #152986 1st Jul 2012 6:46am
spot on ... unscrewed the back of the door to find the locking mechanism and the lock ... MrsBPMan is off to the locksmith tomorrow for a new key
Post #153135 1st Jul 2012 8:02pm
