![]() | Home > Off Topic > Safe cracking ... |
Easy answer Steve, give your money and valuables to me and then you don't need the safe
![]() I would suggest a security registered locksmith is the answer, for obvious reasons ![]() I know one in Yeovil if you are really stuck but I am sure there must be some around Salisbury. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20607 ![]() ![]() |
Probably empty
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Probably easy to see as the "door is open" ![]() Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
Oh yeah ... Ooops ![]() ⛽️🛢️⚙️🧰💪 |
speedymarktd6 Member Since: 02 May 2011 Location: Worcestershire Posts: 102 ![]() ![]() ![]() |
As the door is open you should see some screw heads or bolt heads holding the back panel onto the door if you remove this all the mechanism should be exposed with the lock undo lock nuts fixings and take the lock to a locksmith and you can have a key made for it or they might sugest a new lock and key if its a general design
thanks Speedy .. I can see the screw heads, I'll have a go today and pop a photo up for those curious
spot on ... unscrewed the back of the door to find the locking mechanism and the lock ... MrsBPMan is off to the locksmith tomorrow for a new key
