Home > Technical > center dash removal
ericvv
center dash removal
I need to replace the very small light bulb illuminating the red triangle in the distress lights switch in the middle of the Puma dash.
So need to remove the center dash panel, for this have to unscrew the two bolts left and right with an allen key, and then the dash should unclip starting at the top.
A question, what about the radio? Can I leave that in place and will it come forward together with the center dash cover, or do I have to take the radio out first? You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #152339 28th Jun 2012 5:05am
Eric,
You will need to remove the radio first.
make sure you have the code, should be in the user manual or on your invoice... i had to chase Philippe for my code as it was missing in the manual .. hence sales invoice
Post #152344 28th Jun 2012 6:24am
ZeDefender
Wait a moment!
Are you sure you need to change the bulb? I don't think it lights up the way you would expect it to - there have been some posts about this Wink
*Edit* sorry - just realised you are the "expert" on this topic. I'm going to check mine now, just in case it's a LHD thing... Tell someone you love them today because life is short.
Post #152384 28th Jun 2012 9:40am
Like BP mentioned however I started from the bottom myself not the top. Just be gentle but forceful enough to remove it taking care not to leave marks or damage. There is lot's of pictures in my gallery Thumbs Up No Guts, No Glory.
Post #152386 28th Jun 2012 9:51am
ericvv
ZeDefender wrote:
Wait a moment!
Yes, the bulb burned out. The amazing thing is that Land Rover do not have this bulb as a specific partnbr in their database, so my dealers tried to get away with some poopoo talk, like that switch has no bulb, later they even said, yes there is a bulb, but there are no wires connecting it, and they went as far as checking some 2nd hand Defender to be able to reconfirm that the switch in that one also remained unlit...... Until I showed them a bit later in a brand new Defender in their showroom that the red triangle in the switch does light up when you turn on the lights.
So in the end someone on the forum here (would have to go and find that old post) was kind enough to give me the part number and the suggestion to order it from Rimmer Bros. Which I did, have several spares now for the future.
If I have to take the radio out, I think I will leave it til next visit to Autobritt dealers. Not sure about how to remove that fancy radio in the SVX, and Steve, good point about the radio code. I wouldn't know where that is. have to ask Philippe next time. You never actually own a Defender. You merely look after it for the next generation.
Post #152399 28th Jun 2012 10:35am
Which radio is it? All you'd need is two DIN round radio keys and un-plug the rear plug. The radio code should be stapled or be somewhere in your vehicle handbook. Thumbs Up No Guts, No Glory.
Post #152401 28th Jun 2012 10:45am
JSG
When I removed mine there was enough slack in the loom to slide the radio forward and remove the centre dash without even unplugging it.
On some stereos the code is fixed to the unit - should be removed at PDI and put into the document folder. John
2011 Tdci 110 CSW XS
Post #152408 28th Jun 2012 10:56am
ericvv
Clarion DB568RUSB.
Has a removable front, also have a pair of metallic keys which presume are those DIN keys.
But after removing the front I still cannot find any obvious openings in the unit left and right which accommodate these DIN keys Embarassed .
Don't want to damage anything.... You never actually own a Defender. You merely look after it for the next generation.
Post #152409 28th Jun 2012 11:00am
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I have an older clarion head unit and when that has been fitted into the DIN slot, there is a light plastic bezel that clips around it and masks the holes. The remove it I need to pull out this bezel (very flimsy) thus revealing slots at either side for the release cath things.
I did a quick search for your version and found this picture: http://www.okidoki.ee/item/14364/ which seems to show the same thing.
Post #152414 28th Jun 2012 11:14am
ericvv
That's the one, but think will leave the joy to change this minibulb to the dealer. For them probably 5 minutes altogether, and afraid I will damage something. Tks all advise. You never actually own a Defender. You merely look after it for the next generation.
Post #152417 28th Jun 2012 11:23am
ZeDefender
Hopefully they won't just put it in their pocket and say "What bulb?" Rolling Eyes Tell someone you love them today because life is short.
Post #152421 28th Jun 2012 11:30am
ericvv
Post #152423 28th Jun 2012 11:32am
You certainly don't have to remove the dash, and you may not even have to remove the radio.
You can probably very carefully pop the switch forwards out of its aperture in the panel using a small screwdriver, or better still a pair of paperclips bent into hooks. If it won't come out this way (and it woudl be surprising if it didn't), then pull the radio out so that you can stick your hand in the radio slot and push the switch out from behind. It shouldn't be necessary to disconnect the radio unless you aftermarket unit has resulted in the harness becoming shortened.
Post #152427 28th Jun 2012 11:50am
ericvv
Tks for that suggestion, tried it, but it is not like that. I can without a problem pry off the front part of the switch, the part which you push in/out. But then behind it is the actual switch housing with on the left side in the back the mini light bulb visible. To replace it you have to access the rear part of the housing though.
And even if there is a part which gives a good grip for a pair of plyers to try to pull the damn thing out, it won't budge at all.... So seems access via the rear is the only option. Sad You never actually own a Defender. You merely look after it for the next generation.
Post #152438 28th Jun 2012 12:43pm
K9F
Top Tip!!!!!
At work on the bridge of the vessels I work on there are hundreds of miniature 'p' bulbs....The handiest tool for getting them out.......
A kiddies drinking straw...Gives a firm tight grip when forced over the glass. Honest!!!! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #152439 28th Jun 2012 12:49pm
