![]() | Home > Puma (Tdci) > Clunking noise at low rews and when I turn off the engine |
Woldberg Member Since: 01 Sep 2010 Location: Gjøvik Posts: 4 ![]() ![]() ![]() |
Puma 2011
Hi I get some strange clonking noise when I turn of the engine and when I drive on very low rews. Its sound like if you are banging two steel pipes against each other, 3-4 times as the engine moves as it shuts down. The same sound, but less noisy, when you drive on idle and the engine moves around a bit. Been on youtube and listen to the egr-noises ant it's not that type of sound at all. It stops when the engine stops. Sounds like something that moves and bangs against som thing... ish Suggestions? -Nils Norway |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2661 ![]() ![]() ![]() |
Have a look at this thread and the videos posted there: http://www.defender2.net/forum/topic12243.html --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
I just thought I´ll explain what made the noice.
It was a metal clamp on one of the water hoses that banged into a steel pipe (break pipe? don´t remember now) when the engine moved under startup and shut down and on very low revs. |
