Home > Puma (Tdci) > Clunking noise at low rews and when I turn off the engine
Woldberg
Norway 2011 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Puma 2011
Hi
I get some strange clonking noise when I turn of the engine and when I drive on very low rews. Its sound like if you are banging two steel pipes against each other, 3-4 times as the engine moves as it shuts down. The same sound, but less noisy, when you drive on idle and the engine moves around a bit.
Been on youtube and listen to the egr-noises ant it's not that type of sound at all. It stops when the engine stops.
Sounds like something that moves and bangs against som thing... ish
Suggestions?
-Nils
Norway
Post #151303 20th Jun 2012 9:33am
This is the disintegrating clutch noise familiar to earlier Pumas. Try switching off the engine with your foot on the clutch - the noise will be absent.
If it is the clutch, it is advisable to get a new one fitted sooner rather than later since if it fails completely the repair can be a lot more expensive.
What year is your Defender? Is it the original clutch?
Post #151321 20th Jun 2012 10:38am
Naks
Have a look at this thread and the videos posted there: http://www.defender2.net/forum/topic12243.html --
Post #151337 20th Jun 2012 11:55am
Woldberg
I just thought I´ll explain what made the noice.
It was a metal clamp on one of the water hoses that banged into a steel pipe (break pipe? don´t remember now) when the engine moved under startup and shut down and on very low revs.
Post #326007 25th Apr 2014 3:47pm
