![]() | Home > Puma (Tdci) > strange noise from the front when towing |
When I first read the subject of this thread I had to ask if you'd tried hitching the trailer/caravan to the back instead of the front
![]() 2011MY 110 XS USW Black |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
oh dear no one else appears to have had experienced this
well I hope its just a 'characteristic' then ![]() |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1820 ![]() ![]() ![]() |
Hi Rossy,
Yes mine makes strange noises as well, first gear, no accelerator just moving slowly across a field etc. I thought it was backlash in the transfer box, but there's so much back lash everywhere, it could be anywhere! Keith |
DMAKX Member Since: 18 Nov 2010 Location: In The Middle Posts: 47 ![]() ![]() ![]() |
Hi Rossy,
Mine is exactly the same. It can even do it if you labour the engine when pulling away in second too. It clears once the revs are sufficiently high enough though. It does make you cringe a bit when you hear it, but I guess its one of those many Land Rover traits. ![]() I can't recall my 2.4 making the same noise but it does sound as though it is coming from the transmission rather than the engine. Cheers DMAKX |
thanks lads for those words of comfort !
