Home > Technical > Help with steering wheel...
haworthj
I have a new steering wheel for my Puma. The only problem is, I can't get the original one off the column. It seems to be stuck fast. No amount af tapping/whacking with a mallet will move it...
Any ideas/help would be much appreciated.
And yes, I've undone the bolt Very Happy
James
Post #148735 5th Jun 2012 2:49pm
excossack
Mine was a bit stuck on, so with the nut partly undone(but with enough to allow the wheel to move), I hit the wheel at opposite corners from on top and from behind and eventually it popped off. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #148736 5th Jun 2012 2:57pm
Romadog
Another pair of hands to use hammer while you pull back with both hands, just be aware that when it comes off, not to hit yourself in the face with it ! Surprised Big Cry
Some WD40 or similair left to soak in will also help.
Post #148738 5th Jun 2012 2:59pm
I'd be interested to see some pics of the wheel removed if anyone has any? Thumbs Up
Post #148739 5th Jun 2012 3:04pm
bob neville
Hi James
Puma or earlier ?
Pre puma there are two holes, one either side of the large nut, that you can use a puller on. On my 2009 the holes are there but not the threaded section for the puller.
When I changed my wheel I asked the dealer if there was a specific puller for Puma's and there is but they said it should come off without a puller. Mine did, it almost fell off Laughing
Try this. Put the large nut back on losely, the wheel may make an unexpected bid for freedom !
Gently tap the wheel from behind all the way round. Also try rocking the wheel from side to side.
2013 Defender 90 CSW - sold
Post #148740 5th Jun 2012 3:06pm
bob neville
This is the puller for pre Puma. I have one for my TD5 and it works a treat.
http://www.ebay.co.uk/itm/Landrover-specia...1c27a3f852
Post #148742 5th Jun 2012 3:09pm
bob neville
And this is the 2007 onwards version.
http://www.spxtools-shop.com/jlr/product_info.php?info=p3773.html
Post #148748 5th Jun 2012 3:25pm
v8steve
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Rimini Red
just made a puller for mine (puma)
1 piece 5/6mm steel bar drill 2 6.5mm same spacing as in steering wheel.
2 m6x1.0pitchx25mm set screws put sets through holes in bar thread in to steering wheel,couple of turns with spanner and off she pops.
this is after the big nut has been removed. 110 xs s/wagon
s3 swb soft top
Post #148787 5th Jun 2012 6:52pm
T1G UP
slacken nut and bang both sides.
Post #148789 5th Jun 2012 7:01pm
JeremyJ
Put the nut on a couple of threads and hit each side of the wheel with your fists quickly. It will eventually come off, I've always done it that way as its quicker than finding a puller!
Post #148791 5th Jun 2012 7:07pm
T1G UP
thats what i meant but couldn't be asssed to type it!
Post #148795 5th Jun 2012 7:44pm
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
if it's never been off before it's amazing how hard you have to hit it to get it off. I was almost convinced I was going to snap my wheel trying to get it off Embarassed
Post #148833 6th Jun 2012 3:55am
Bob
There have been two different steering wheels used post 2007; the one that looks like it ought to have an airbag (it has a strange bulbous growth in the middle), and a flat one without the growth.
The bulbous one is (I believe) equipped with holes for a puller, the flat one is not.
Either should come off without the use of a puller, but as written above it is very important to leave the nut on a few threads when pulling it off or you will whack yourself in the face.
Post #148882 6th Jun 2012 11:58am
nickellese
United Kingdom 1985 Defender 90 V8 Petrol ST Cobar Blue
James,
I made a very crude 'puller' for my Puma after virtually hanging off my old steering wheel with no result.
Its VERY basic but did the job in 30 seconds.
If you have the two threaded bolt holes in your current steering wheel I would be happy to post it to you, if you promise to post it back! Laughing
Nick
Post #149042 7th Jun 2012 2:56pm
