Home > Td5 > Rear door pre/post 2001 swap
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Hi,
The rear door on my 2001 TD5 90 has a rust hole at the bottom left corner. It's nothing major, but my OCD is telling me to get a new door.
Is it possible to use the later 1 piece doors on the models with the 2 piece doors. Is it a straight swap..? I assume some of the fittings are different..?
Simon
Post #148508 4th Jun 2012 8:22am
Fits straight over. Hinges are the same but the lock assy is different. you'll need to play with the wiring a bit, as the newer one has a different plug on the wiper/heated window loom, but you can just remove the old loom and swap it over to the new door.
Post #148598 4th Jun 2012 5:12pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
I have this to do as soon as possible because my wee is particularly fed up of the new door being proper up in the kitchen. ............it's only been 6 months.
Post #148607 4th Jun 2012 6:32pm
couplands
Thanks, is the wheel carrier different too..? I currently use a separate wheel carrier, but may go back to a door mounted carrier.
Simon
Post #148658 4th Jun 2012 11:49pm
Yes, the wheel carriers are different (the later Td5 door carrier looks like a discovery one)
If you've got a separate carrier frame, i'm sure you could fabricate something to make it fit the newer door.
Post #148664 5th Jun 2012 6:17am
SteveT247
England 2002 Defender 90 Td5 XS CSW Bonatti Grey
Have a read of this Simon. The related posts at the bottom cover fitting, wiring etc etc.
http://www.landroverexpedition.com/technic...-td5-door/
HTH
Steve
Post #148665 5th Jun 2012 7:23am
couplands
Brilliant, thanks Steve.... Thumbs Up
Post #148666 5th Jun 2012 7:35am
SteveT247
No problem. Thumbs Up
Post #148668 5th Jun 2012 7:39am
Romadog
Anyone done the next step where they have a 300tdi loom and have fitted a Td5 rear door and the later Td5 dashboard, re the different way the switches are wired ?
Post #148673 5th Jun 2012 8:17am
marsie
England 2010 Defender 110 Puma 2.4 XS CSW Galway Green
Planning on doing the same door upgrade to mine when i find one for sensible money Rolling Eyes . The advantage for me is that i can bolt a disco2 wheel carrier to it as i am now on D2 axles. Also they are supposedly less prone to cracking when a spare is fitted to them?
Paul Thumbs Up
Post #149084 7th Jun 2012 7:54pm
JSG
marsie wrote:
... Also they are supposedly less prone to cracking when a spare is fitted to them?
Paul Thumbs Up
The one piece door is supposed to be stronger and hold up better. Thumbs Up John
2011 Tdci 110 CSW XS
Post #149099 7th Jun 2012 8:58pm
