Home > Td5 > Rear door pre/post 2001 swap |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6098 |
Fits straight over. Hinges are the same but the lock assy is different. you'll need to play with the wiring a bit, as the newer one has a different plug on the wiper/heated window loom, but you can just remove the old loom and swap it over to the new door.
4th Jun 2012 5:12pm |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 |
I have this to do as soon as possible because my wee is particularly fed up of the new door being proper up in the kitchen. ............it's only been 6 months.
4th Jun 2012 6:32pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
Thanks, is the wheel carrier different too..? I currently use a separate wheel carrier, but may go back to a door mounted carrier. Cheers Simon |
4th Jun 2012 11:49pm |
Yes, the wheel carriers are different (the later Td5 door carrier looks like a discovery one)
If you've got a separate carrier frame, i'm sure you could fabricate something to make it fit the newer door. |
5th Jun 2012 6:17am |
SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491 |
Have a read of this Simon. The related posts at the bottom cover fitting, wiring etc etc.
http://www.landroverexpedition.com/technic...-td5-door/ HTH Steve |
5th Jun 2012 7:23am |
Brilliant, thanks Steve....
5th Jun 2012 7:35am |
No problem.
5th Jun 2012 7:39am |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1749 |
Anyone done the next step where they have a 300tdi loom and have fitted a Td5 rear door and the later Td5 dashboard, re the different way the switches are wired ?
5th Jun 2012 8:17am |
marsie Member Since: 17 Nov 2011 Location: sheffieldish Posts: 532 |
Planning on doing the same door upgrade to mine when i find one for sensible money . The advantage for me is that i can bolt a disco2 wheel carrier to it as i am now on D2 axles. Also they are supposedly less prone to cracking when a spare is fitted to them?
Paul |
7th Jun 2012 7:54pm |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
The one piece door is supposed to be stronger and hold up better. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
7th Jun 2012 8:58pm |
