Home > Td5 > Noisy fuel pump
Page 4 of 6 <123456>
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Yer the thing was they were advertised as genuine shown in bags as yours
Oh well new ones to e ordered Wednesday
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #148550 4th Jun 2012 12:30pm
defninety
1985 Defender 90 Td5 XS CSW Bonatti Grey
Final thing that may be worth checking if not already done so....
Post #148559 4th Jun 2012 1:07pm
wslr
defninety wrote:
If they are not supplied like this, then don't bother. Not sure how much you paid/saved but you should be able to get the all for around £30 straight from LR dealer, seems the safest and easiest way to ensure you have the correct ones.
The O-rings are green tinted. These are suitable for contact with fuel and oils, which would break down a plain rubber O-ring. BTW, LR manufacture the Td5 Fuel Pressure Regulator using standard rubber O-rings, which explains why some leak from new.
If you are going to rebuild your own FPR, you ideally need to also chamfer off the internals. This poorly manufactured metal can damage the O-ring when they are inserted, thus why the odd one can leak from new.
There is a recent (December 2011) SSM (SSM34046 - TD5 Cylinder Head Damage At Injector Location Bores) on TOPIx outlining why and how to do this, as if it is not done correctly, the injectors could be damaged, and also there is the possibility of the head being cracked and leaking fuel into the sump.
If you use the correct SPX tool for this job, it is idiot proof anyway. The lobe has to be in this position otherwise the tools will not fit. If you are using a heel bar or something to force it out, then beware.
Post #148618 4th Jun 2012 8:43pm
big steve
Well just sent trilicklandrover an email regarding the seals
New ones from landrover being ordered tomorrow hmmm
I just hope it isn't something else
Post #148689 5th Jun 2012 11:43am
Laurie
Steve
That's why I'm waiting.
I'm wondering, if they were not as described, can I claim the cost of repairs?
Post #148692 5th Jun 2012 11:50am
big steve
Yer true s ii said befor seems strange both from the same place Both gone wrong in a matter of miles ?!
Post #148694 5th Jun 2012 11:52am
big steve
have you found anything out laurie
steve 2015 2.2 tdci hardtop xs
Post #148907 6th Jun 2012 5:20pm
Laurie
steve
They're road testing it tonight, Will find out in the morning.
Post #148978 6th Jun 2012 11:49pm
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
mine went noisy recently after changing the fuel filter - apparently quite a common issue according to my Landrover mechanic mate. I got one of the £80 ebay ones to replace it and he said it was near enough identical to a genuine one that was going to cost easily 3 times as much.
Hardest part was getting the flippin fuel tank out to change it Laughing
Post #148981 7th Jun 2012 12:50am
Arbman Al
Received my proper genuine seals today, all in individual bags with landrover on them Thumbs Up
When I took them out, to be honest, they did not look any different from the suspect ones I put up a photo for a few posts ago.
Not going to change them just yet, as others have been changing them due to poor starting, lack of power etc.
My pump sounds noisy (not had a td5 before, so might be normal!), and I do not have any starting issues, power loss or oil level rising - just only getting 16mpg Big Cry 1996 Defender 130 converted to TD5 and auto
1975 Triumph Stag 3.0 V8
Post #149073 7th Jun 2012 8:14pm
Laurie
What colour are they?
Post #149117 8th Jun 2012 1:40am
Laurie
I submitted the following to the seal suppliers this evening.........
Dear Sirs
The items I received were not as advertised, i.e. not in original manufacturers packaging.
They failed in less than 100 miles after being fitted by a reputable Land Rover service company. This company tells me that they were not original since original O rings are of a dark green colour.
I require you to submit absolute proof of originality or refund my payment to you plus the cost of replacement by my service engineers.
Yours, very sincerely Laurie Wright
Post #149118 8th Jun 2012 1:57am
Arbman Al
The seals are definately dark green, where as the ones from Trillick were black. The washers look the same, bright copper colour (as in my photo above) 1996 Defender 130 converted to TD5 and auto
Post #149123 8th Jun 2012 7:47am
Laurie
No reply yet
Post #149151 8th Jun 2012 11:16am
Laurie
Just received......
Hi
If you are not happy i will offer a full refund for the money you already paid us.
Thank-you
Post #149158 8th Jun 2012 12:10pm
