Home > Td5 > Noisy fuel pump
Page 2 of 6 <123456>
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Hi Laurie,
Is it possible to make the hole without removing the tank? I keep thinking of preparing for when mine needs replacing.
I would be interested in any photo's or measurements once yours is finished if that is possible?
Thanks,
Steve
Post #144154 9th May 2012 5:47pm
Laurie
Steve B wrote:
Hi Laurie,
Thanks,
Steve
Will try. I'm not doing it myself. Gave up laying in puddles after my 60th birthday Wink
Post #144163 9th May 2012 6:04pm
Steve B
Ah ok, if you have the weathe we are having you would need a snorkel soon Smile
Hope it goes well, interested to see it though once finished.
Steve
Post #144248 9th May 2012 9:16pm
Laurie
She's booked in on the 16th, we'll see what happens.
Post #144272 9th May 2012 11:17pm
Laurie
New Bearmach fuel pump fiitted and noise has gone away.
Had to remove tank as there's a stiffening rib under the floor directly over the pump. Would have weakened the floor cutting through it.
Post #145734 18th May 2012 12:27pm
Arbman Al
diesel_jim wrote:
GarethR wrote:
I presume that injector seals make the noise emanate from the engine bay, faulty pump from underneath the tank? Is this correct?
I think the injector seals let air pass through the pipe, leading to air getting sucked through the pump, making funny noises.
I think.... Question Question
If the injector seals are leaking, does the diesel not get into the engine oil, and so show up by giving a higher reading on the engine oil dipstick? 1996 Defender 130 converted to TD5 and auto
1975 Triumph Stag 3.0 V8
Post #146949 24th May 2012 10:41pm
landy andy
No, it allows the air that is compressed in the cylinder back into the fuel system.
The seals would have to be very bad, or have a cracked head to get diesel in the fuel.
Post #146950 24th May 2012 10:46pm
JWL
I've had an extremely noisy pump for the past 2 years, the injector seals went along with oil in the injector harness. I had tose done and since then just lived with it, if it packed up then I'd change it, wasn't going through the rigmarole of tank out if I didn't have to. I changed the pressure regulator seals about a fortnight ago and that didn't make a difference to the pump noise but on Tuesday night I filled it up to allmost full, I don't often put in much more than half a tank but as I had a long run yesterday I didn't want the hassle of getting diesel through the day. Ever since then it has run quietly even when the level in the tank is down low again. Now we'll see if it's on it's last legs or it has gone through a self healing process Whistle
Post #146952 24th May 2012 11:14pm
ajps72
2001 Defender 110 Td5 SW Chawton White
Hello all, I had the same problem with a noisy pump that had the internal filter clogged, I cleaned and works perfectly now.
It also starts whining when the fuel filter is dirty. Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #146956 24th May 2012 11:40pm
Arbman Al
Thanks for the reply. Think I'll change the seals as only getting 16mpg Big Cry and the pump is noisy.
Being a 130 tipper it is easy to get to the pump Thumbs Up
Noticed that the filter head had broken away from the chassis, what is the best place to buy on e from?
Cheers...Al 1996 Defender 130 converted to TD5 and auto
Post #146963 25th May 2012 8:32am
Laurie
The 'so called' OE seals I've just had put in mine have given out after two weeks. Sad
Post #148256 2nd Jun 2012 11:26am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
iv just fitted new seal in the disco and the pump has become noisy they were from ebay ?
could this be down to the seals 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #148259 2nd Jun 2012 12:14pm
JWL
I got mine via fleabay but they did come from one of our site sponsors(LRS). It's got to be the first time my Defender hasn't marked it's terratory for years Thumbs Up probably means all the oils have all gone, must get round to checking some levels Whistle
Post #148280 2nd Jun 2012 4:48pm
big steve
well after doing about 14 miles the disco has stopped twice and diesel is getting in to the oil ?
the only thing i have done is the injector seals ?
bought off ebay as genuine but were loose when arived not packeted
is there anything you can do wrong when fitting them ?
steve 2015 2.2 tdci hardtop xs
Post #148301 2nd Jun 2012 8:06pm
Laurie
big steve wrote:
...bought off ebay as genuine but were loose when arived not packeted
Same here. Sad
My fitters say they were the wrong colour for genuine.
Post #148358 3rd Jun 2012 2:24am
