Home > Maintenance & Modifications > More lock required
Page 1 of 3 123>
familymad
More lock required
Wife would like a bit more turning and has driven a mates Landy with bigger offset rims. Don't really want to spend on a set of ZU's yet so anyone using wheel spacers?
Can of worms and now opened? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #145640 17th May 2012 9:31pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
simple solution 1st. have you altered your steering stops to max the turning circle? BM52
Post #145650 17th May 2012 9:46pm
Re: More lock required
familymad wrote:
....so anyone using wheel spacers?
Yes.
Post #145698 18th May 2012 8:15am
Me too. My 110 is more maneuverable than my wifes' old DII, despite the longer wheelbase. Darren
Post #145707 18th May 2012 9:02am
Laurie
My 90 had the steering stop set so badly at the factory the wheels were over 30mm off the radius arms on full lock.
Took 15 mins to adjust them to about 2mm.
Post #145711 18th May 2012 9:39am
Zagato
How do you adjust them Laurie?
Post #145716 18th May 2012 10:38am
Laurie
Ideally put the front axle on stands.
Turn the wheel to full lock (without the engine running)
The stops are bolts with locknuts mounted on the rear of the swivel housings.
Screw them in until the tyres just miss the radius arms.
Then recheck with the engine running.
Post #145718 18th May 2012 10:46am
Zagato
Many thanks Thumbs Up
Post #145722 18th May 2012 11:02am
My 110 (285's on Boosts with 30mm spacers) has a much better turning circle than my Disco2 (265's on standard alloys, no spacers). The Disco will, just about, manage to orbit a moderate sized planet on full lock. The 110 will orbit a reasonably small asteroid.
Post #145731 18th May 2012 11:26am
farmer giles
is this correct: if i have wheels with a zero offset they will give a better turning circle than alloys with a +30 offset?
Post #146213 21st May 2012 9:02am
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
Yes, as long as you adjust the lock stops.
Post #146214 21st May 2012 9:10am
farmer giles
cheers Thumbs Up
Post #146216 21st May 2012 9:13am
familymad
This HAS transformed the truck for the good lady and also means I have a better chance of looking goo reversing my car trailer!!
Am gonna try a set of 30mm spacers this weekend but you say they don't improve it?? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #147608 29th May 2012 8:39pm
ickle
Joe,
alloys with 0 off set and alloys with 30mm offset and 30mm spacers are the same thing! (Inner wheel edge will be in the same position if it is the same width of wheel)
I had a better lock with std boosts and 265's and 30mm spacers than the new 0 offset Silverline 8" alloys and 285 tyres.
Adjust the lock stops to the max for greatest benefit.
Keith
Post #147611 29th May 2012 8:49pm
farmer giles
Cheers Keith,
i hope to be participating in the blindo group buy that tig might be organising. if the wheels are suitable i was wanting to put them on the old 300tdi with 235 tyres on them. currently the 300 has modulars which must have a negative or zero offset as the wheels sit right under the spats with no spacers. i would prefer not to use spacers.
watch this space......
Post #147887 31st May 2012 11:00am
Page 1 of 3 123>
