Home > Maintenance & Modifications > More lock required
Page 2 of 3 <123>
mrandmrsh
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
I was all ready to fit spacers (even got the NFU to agree to cover them at no charge) to my 110 on standard wheels n tyres. Read this and climbed under car and screwed in the bump stops and the difference without any change other than tightening up a couple of bolts - it feels like a different vehicle altogether.
On 235s I have adjusted the stops so there's around a fingers' space between the control arm and the wheel on full lock.
My question is if I fit spacers how much more can I adjust the stops safely without risk of damage to the vehicle?
C 2015 110 USW XS in Santorini with premium contrast leather seats in tan/black, black headlining and with Dual Finish alloys (in the garage, now on Wolf rims with Goodyear MT/Rs)
2012 '62' 2.2 X-Tech 110 USW now gone ...
1984 90 soft top with full roll cage, 200 tdi engine etc now sold
2012 USW XS 2.2 "FUU" now gone....
Post #148113 1st Jun 2012 12:32pm
xatzhs
Laurie wrote:
Ideally put the front axle on stands.
Turn the wheel to full lock (without the engine running)
The stops are bolts with locknuts mounted on the rear of the swivel housings.
Screw them in until the tyres just miss the radius arms.
Then recheck with the engine running.
Is it essential to have them on axle stands? Is it easy/safe enough to do it without?
Post #148262 2nd Jun 2012 11:44am
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
I would not even contemplate this task without stands Shocked BM52
Post #148271 2nd Jun 2012 1:48pm
mrandmrsh
All I did was crawl under the car as it was stood on the ground with the steering straight and screwed one side in then moved car back and fwd on full lock to see if I had gone too far/far enough. Then same with the other side. Done. No jacks, no stands just two 19mm spanners.
Post #148492 3rd Jun 2012 10:50pm
familymad
I believe it's another big difference to the circle with 30mm spacers and why I'm considering them. The wife will be even more impressed.......... 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #149822 11th Jun 2012 9:03pm
mrandmrsh
Question for me is how much more can you safely wind the lock stops in over and above a standard car on standard alloys with standard 235 tyres?
If I was on 265 tyres I would think spacers would be critical but I am just not sure how much more you will get on standard set-up.
Would love to know.
Post #149887 12th Jun 2012 11:10am
familymad
Someone will answer this I'm sure but if I put a 30mm offset on the wheels (using spacers) I would hope to be able to wind in the stops by the same amount again 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #149991 12th Jun 2012 8:36pm
ZeDefender
I used to have 235s on Boosts (ET33 offset) with 30mm spacers and adjusted stop - awesome improvement Thumbs Up
Now I have 265s on Dotz Dakar rims with ET8 offset, no spacers and adjusted stops = almost as good.
Zus have ET11 offset, so with no spacers and 235s or 265s and adjusted stop they should also be a good improvement over factory. Tell someone you love them today because life is short.
Post #150042 12th Jun 2012 10:35pm
T1G UP
mine rubs as i've wound the stops right in.
i cn turn round ok now
Post #150043 12th Jun 2012 10:38pm
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
Mine rubs when you turn left but not right... sounds like my stops are set a bit wonky then Confused
Handy thread this one Mr. Green
Post #150052 13th Jun 2012 1:05am
xtreme
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Sumatra Black
C
Did the same today, car 2 days old! Difference incredible!!! Thanks!
Post #153778 5th Jul 2012 5:09pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Had 30 mm spacers fitted and stops done Tuesday wow what a difference almost drive-able in car parks now Thumbs Up It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #153805 5th Jul 2012 6:32pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
im running 35 inch simex with no rubbing Whistle
and it turn great
can get right round a mini roundabout easy
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #153827 5th Jul 2012 7:57pm
How about if the stops are set equally already counting the turns exactly and equally on both sides surely that would do the same as well. And just check after it's not over done.. If it is reapeat but anti clockwise. I yet have to have a go at this yet. No Guts, No Glory.
Post #153834 5th Jul 2012 8:36pm
Finally got round to checking and adjusting the steering lock stops today but I find that it's pretty much to the maximum I'd be happy to have it already. I can't help but think having it to close is not a good idea after all when tyre's are muddy it will bind between the tyre and the radius arm and if you were un-lucky enough to get a small stone in that gap it wouldn't be good so I'm leaving mine alone. No Guts, No Glory.
Post #155701 15th Jul 2012 11:22am
Page 2 of 3 <123>
