Home > Maintenance & Modifications > Shelf Up In The Roof!
Page 3 of 3 <123
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
2 cents
Sheet material shelves tend to collect dust, prefer netting or similar. Also easier to see what you have up there and dont restrict view as much when empty.
For the price they cost you cant go wrong experimenting with these ikea stainless kitchen shelves
:thumbsup:
Post #146937 24th May 2012 9:44pm
ZeDefender
Re. shelves (and dog guards), does anyone know if you can fit rivnuts into the Puma SW headliner or where/if there is something solid to fix a rivnut into the roof behind the second row seats (pretty much in the middle of the guard above)?
Sorry for the minor hijack Whistle
Matt Tell someone you love them today because life is short.
Post #146965 25th May 2012 8:36am
ibexman
Theres a central roof rib running through the centre unscrew interior light and you can see it i use 6mm rivnuts to fix my consoles there Thumbs Up
Post #146973 25th May 2012 9:18am
ZeDefender
Brilliant - many thanks Bow down
Post #146998 25th May 2012 10:54am
Mark_110DCPU
United Kingdom 2001 Defender 110 Td5 DCPU Chawton White
I have this net in the back of my DC - it is attached to the horizontal hoodsticks with bungee to give it some spring, and means that things like sleeping bags and thermarests are effectively held up there.
I am sure the same could be acheived in a hardtop without too much problem. There are even brackets available from the same site to attach the net to...
Don't have any pictures with me I am afraid, but can post some up later if its any use.
hth
Mark [:O|===|O:] 2001 110 TD5 Doublecab
Post #147023 25th May 2012 12:54pm
ZeDefender
Thanks for the info Thumbs Up
Hope this doesn't annoy you but just to check (feeling a little nervous), if I drill to put in a rivnut here:
what will I actually drill through (e.g. headliner X mm thick, then...) and how far before the roof leaks?
Cheers,
Matt
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Tell someone you love them today because life is short.
Post #147250 27th May 2012 1:46pm
Drover
Australia
A few ideas for storage... Very Happy
BlackWidow Drawer and Top shelf
Platfrom instead of rear seats
Shelf above platform
Post #147320 28th May 2012 1:45am
Bottom picture.....that looks a great bit of kit, I've been watching this with interest, I'm going to 'fashion' something up Wink
Post #147324 28th May 2012 8:50am
Drover
Australia
Hey Greeni,
I just used some 20mm square tube and made a frame to fit around a basket that I bought from a Business in Australia called "Howard’s Storage world" it supposed to be used in a wardrobe. I just cable tied the frame and basket together.
Then bent up some 30mm flat bar to make the support arms and side bracket that I screwed into the old mounting points used for the grab handles. The back of the basket just bolts to the cargo barrier.
It is solid as rock.
All up under 60 AUD's or 40GBP. Thumbs Up
Post #147328 28th May 2012 9:25am
Cheers Drover, sounds quite simple Thumbs Up
Now to search for some baskets...a trip to a retail supplier I reckon !
Post #147335 28th May 2012 10:15am
Zagato
Decided to keep the rear seat in so needed something flexible to retain headroom and bought a £16 trailer cargo net from Halfrauds. It's a strong one with big clamps that hook nicely into the interior, quick and easy to take down if necessary!
It's strong but for heavy stuff a permanent solid shelf would be needed.
Post #148516 4th Jun 2012 9:51am
Page 3 of 3 <123
