Home > Td5 > Think I've found the problem
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Disconnected the ecu and it must have a gallon of oil in it whoops
What's the best way to get all the oil from the loom and the ecu ???
Regards steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #146500 22nd May 2012 9:20pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
I guess this is a TD5? The loom from the injectors needs replacing. I took the ecu out and let it drain for a couple of days and then cleaned it with some pcb circuit board cleaner, it comes in a spray can probably avalible from Maplins. I then cleaned the plug and loom under the seatbox with brake cleaner and gave it plenty of time to dry. I also found I had to clean the plug and loom for a few days after as the oil keeps coming.
Post #146524 22nd May 2012 10:29pm
T1G UP
new injector loom, brke cleaner fliud in the plug and prop it up and let it drain out.looms £20 and 30 mins to do.
Post #146528 22nd May 2012 10:36pm
big steve
Cheers guys any other cleaning suggestions what about the insides of the ecu ?
Steve 2015 2.2 tdci hardtop xs
Post #146728 23rd May 2012 7:35pm
Zagato
Remember when you use to take it to a dealership and they would automatically say new ECU sir £400 Shocked Rolling Eyes New loom and clean up sorted mine also Wink
Used to be the same with injectors but think they can suss which one is playing up these days Thumbs Up
Post #146730 23rd May 2012 7:40pm
big steve
Yer I appreciate that but what should I do with the inside of the ecu ?
Post #146736 23rd May 2012 7:57pm
bell-auto-services
Remove the orange seal from the ecu end plug for a few weeks after cleaning and any left in should run out slowleyand not just sit sealed at the lowest point inside the plug connector.
Pete
Post #146744 23rd May 2012 8:08pm
big steve
Cheers pete hopefully get it off to you soon Thumbs Up Thumbs Up Thumbs Up 2015 2.2 tdci hardtop xs
Post #146747 23rd May 2012 8:23pm
big steve
well got up nice and early this morning and removed the injectors one by one fitting the new o-rings and copper washers then fitted the new injector loom am gooing to find the manual tommorow and check the setings to the injectors as on my past td5 soemone had cahnged them and when put back to how they should be it released some torque from somewhere
so whats next do i take the fuel regulator off and change all the seals in it or is it best left alone until it goes wrong ?
kind regards steve 2015 2.2 tdci hardtop xs
Post #147197 26th May 2012 8:24pm
