![]() | Home > Maintenance & Modifications > R380 Transfer box matting |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
Have a look at ashcroft you can put in new gears. Could be an option.
http://www.ashcroft-transmissions.co.uk/in...oductId=44 BM52 |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
I have a box from a discovery in my tdi 90 , made a lot of difference. Not exactly sure which model but probably
a disco 1. Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
I had an ashcroft gear set installed into my 110 td5, it was one of the best mods ever, much much quieter and a little more fuel friendly.
Yep - did this in my TD5 90 TR. Fantastic, cruised at 70 at the same revs 55mph used to be ![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5922 ![]() ![]() ![]() |
Do you get the same effect by swapping out the Defender TC for a Discovery TC, and how would the change in gearing effect the towing ability of a loaded Defender? 1999 Defender TD5 110
We towed a heavy trailer with it and it was fine - mine also had a Dastek chip and a bigger intercooler. The Ashcroft conversion just swops the high ratios and leaves low range as standard Defender - a complete Disco box swop would give you Disco low range ratios as well. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6161 ![]() ![]() ![]() |
[quote="JSG"]
Disco low range is the same as defender... all the LT230 t/boxes have the same low range gearing. I've got one on my 110. pulls great, although sometimes hillstarts need a bit of clutch slipping... and if i've got my 255/85s on, then I usually slip into low range 2nd to pull away on steep ones. |
Cool - wasn't aware of that. Cheers. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
