Home > Maintenance & Modifications > R380 Transfer box matting
Peter
United Kingdom 2005 Defender 90 Td5 SW Epsom Green
Ok if I wanted to make my 55 td5 90 more Motorway friendly which transfer box from which vehicle should I use ?
Post #146526 22nd May 2012 9:31pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Have a look at ashcroft you can put in new gears. Could be an option.
http://www.ashcroft-transmissions.co.uk/in...oductId=44 BM52
Post #146529 22nd May 2012 9:38pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
I have a box from a discovery in my tdi 90 , made a lot of difference. Not exactly sure which model but probably
a disco 1.
Dj 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #146536 22nd May 2012 9:57pm
I had an ashcroft gear set installed into my 110 td5, it was one of the best mods ever, much much quieter and a little more fuel friendly.
Post #146558 23rd May 2012 6:20am
JSG
Yep - did this in my TD5 90 TR. Fantastic, cruised at 70 at the same revs 55mph used to be Thumbs Up John
2011 Tdci 110 CSW XS
Post #146617 23rd May 2012 10:20am
excossack
Do you get the same effect by swapping out the Defender TC for a Discovery TC, and how would the change in gearing effect the towing ability of a loaded Defender? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #146644 23rd May 2012 11:50am
JSG
We towed a heavy trailer with it and it was fine - mine also had a Dastek chip and a bigger intercooler.
The Ashcroft conversion just swops the high ratios and leaves low range as standard Defender - a complete Disco box swop would give you Disco low range ratios as well. John
Post #146683 23rd May 2012 2:52pm
[quote="JSG"]
Disco low range is the same as defender... all the LT230 t/boxes have the same low range gearing.
I've got one on my 110. pulls great, although sometimes hillstarts need a bit of clutch slipping... and if i've got my 255/85s on, then I usually slip into low range 2nd to pull away on steep ones.
Post #146707 23rd May 2012 5:06pm
JSG
Cool - wasn't aware of that. Cheers. John
Post #146738 23rd May 2012 6:59pm
