Home > Maintenance & Modifications > Good idea or stupid - Sound proofing method
Page 2 of 2 <12
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Quote:
It absorbs water, don't do it!
Too true. Most of this stuff is reliant on moisture to cure it properly in the first place. Some of the brands even tell you to spray water on first to start the process.
Pete
Post #146539 22nd May 2012 10:03pm
mermoto
the concept may not be quite so daft - check this out
http://www.automotto.com/entry/lithuanian-...eath-trap/
Mermoto
Post #146542 22nd May 2012 10:38pm
xatzhs
Mermoto
Ummm I'm pretty sure all that article is saying is how daft it is... Whistle
Twice referred to as a 'death trap'...
Impressive what he did with it, credit where credit's due!
Post #146550 22nd May 2012 11:39pm
if you put it in your chassis you will never be able to weld it due to the foam catching fire and the fumes ..
Post #146559 23rd May 2012 6:22am
JSG
Glynparry25 wrote:
....... At a glimps I thought you were going to put the cup of foam in the 'Cup holder' on the engine, lol.
Rolling with laughter Rolling with laughter Rolling with laughter
Glyn Dog Sheep
Rolling with laughter Rolling with laughter Rolling with laughter John
2011 Tdci 110 CSW XS
Post #146620 23rd May 2012 10:27am
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
Dont do it!
my 1953 tatra came as a diy camper conversion. The guy isolated it with this type of sprayfoam.
When i removed the interior and the foam i was soaking wet... that was in 30° ambient temp and the tatra stored inside for more than 6 months. Not only all panels were corroded but the frame of the box, doors etc, which are wood were severely rotten. Repairing these was hell.
I avoid all types of glue-on or full surface contact with panels as much as i can. Water gets trapped and will never escape.
With the tatra, which is a forward control type of setup (so engine between driver and passenger) i had the best effect of sound damping by bolting a second sheet of metal on the inside of the engine cover. Used 3cm long nuts to create a void between original cover and new sheet.
The sheet got sprayed in truckbed liner to make it a bit more damping and heavy.
Liner will absorb and change freq and sheetmetal will reflect the high freqs was the idea behind it.
Maybe you could try something like this on the inside of the bonnet?
Smile
Post #146671 23rd May 2012 1:40pm
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Your tale reminds me......Shortly after the 'velvet revolution' I had a friend working as an architect in Prague. I went out to look at getting a job out there with his firm. While there, I mentioned my interest in Tatras, and was sohwn to a dusty lockup by an English ex-pat, where I was offered not one but two Tatra T87s (one good, the other not so) for 20 grand!
At the time I thought that it seemed opportunistic, and I was broke.
Last T87 I saw, was selling for....
http://www.carandclassic.co.uk/car/C200769
Big Cry Big Cry Big Cry
tatra805 wrote:
Dont do it!
Smile
2010 110 XS USW (the slow one)
1960 Alfa Romeo Giulietta SZ (the fast one)
2005 Ducati ST3
1954 Sunbeam S8
Post #146795 23rd May 2012 11:36pm
Page 2 of 2 <12
