Home > Maintenance & Modifications > Good idea or stupid - Sound proofing method
mermoto
OK mateys what do you think.
Been thinking about the engine compartment sound proofing options and I know all about the lead blankets and adhesive pads etc but what about this?
As the inside of my bonnet is sprayed with Dinitrol, sticky pads would be a faf. So what if I was to remove the bonnet and fill it with expanding fire proof foam which when set firm could easily be trimmed around the edges for a neat smooth finish. I would guess it would have reasonable sound proofing qualities, be fire retardent and dead easy to do and because the Puma bonnet has lots of gaps it should hold in place regardless of the Dinitrol.
Any drawback? What am I missing? Whistle
http://www.uksealants.co.uk/product.asp?idproduct=201
Mermoto[/img]
Post #146384 22nd May 2012 10:48am
Can't see why it shouldn't work
Remove the bonnet, lay it upside down and spray away. Once its set, like you say, a nice long blade to trim it down.
Post #146405 22nd May 2012 1:45pm
dgardel
Italy
No Please!!!!
Low sound proofing capacity (too much lighter and closed cell) and it trap the water / humidity.................. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #146408 22nd May 2012 1:48pm
MartinK
dgardel wrote:
No Please!!!!
DGARDEL - how are you getting on with the acoustic cover off the 2.2 installed on your 2.4 ??? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #146410 22nd May 2012 1:50pm
mermoto
dgardel wrote:
No Please!!!!
..but wouldn't expanding foam be closed cell so not able to absorb water?
..is humidity likely to occur under the bonnet, I realise that the engine can be very hot and outside at night the temperature can fall way below but I have never seen any condensation on the inside of the bonnet. Also with the foam in direct contact with the underside would that not prevent water droplets forming?
Just thoughts ???
Mermoto
Post #146412 22nd May 2012 1:54pm
dgardel
Italy
mermoto wrote:
dgardel wrote:
No Please!!!!
Just thoughts ???
Mermoto
Water can goes from metal surface and foam.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #146418 22nd May 2012 2:07pm
dgardel
Italy
MartinK wrote:
dgardel wrote:
No Please!!!!
Not Yet Big Cry Big Cry Big Cry
But I want to do during this weeks Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #146419 22nd May 2012 2:07pm
Glynparry25
....... At a glimps I thought you were going to put the cup of foam in the 'Cup holder' on the engine, lol.
Rolling with laughter Rolling with laughter Rolling with laughter
Glyn Dog Sheep
Post #146421 22nd May 2012 2:13pm
I'd say that stuff is too light-weight to offer any significant sound proofing qualities. Vehicle sound proofing usually relies on density. Darren
Post #146422 22nd May 2012 2:22pm
MK
isnīt highly flamable? Puma 110" SW
Post #146430 22nd May 2012 2:58pm
No, it's 'fire rated expanding foam'. Its' intended use is stopping of holes through fire rated walls, ceilings, etc. around services and the like in buildings. Darren
Post #146431 22nd May 2012 3:04pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Could be sprayed behind the dash to stop those pesky rattles Mr. Green
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #146434 22nd May 2012 3:14pm
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
And imagine what fun you'd have afterwards when trying to find the cause of that 'random' short circuit. Rolling with laughter
DJ
2010 110 XS USW (the slow one)
1960 Alfa Romeo Giulietta SZ (the fast one)
2005 Ducati ST3
1954 Sunbeam S8
Post #146440 22nd May 2012 3:57pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
I did think about filling the chassis with expanding foam to stop water getting in and to prevent condensation Shocked may even make it float Rolling with laughter
Post #146486 22nd May 2012 8:21pm
ickle
It absorbs water, don't do it!
Post #146495 22nd May 2012 8:45pm
