Home > Maintenance & Modifications > A decent subwoofer speaker or a 'bassy' speaker?
Page 2 of 4 <1234>
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
Easy way is to drop from the back of the stereo to the fusebox, there is a small conduit sized hole which the RCA cables just fit throught.
From therem accross the tunnel under the carpet/mats and your there.
Not the tidyest but it works. 2002 Defender 110 DC
Post #143970 8th May 2012 4:29pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
that's what i did as well, simple result and effective Thumbs Up BM52
Post #143987 8th May 2012 6:39pm
ashfordsv
Ireland 2006 Defender 90 Td5 SW Java Black
Here is my Pioneer sub woofer fitted before i took the bulkhead out
and here it is after
Post #144004 8th May 2012 7:32pm
Jammer600
United Kingdom 2007 Defender 90 Puma 2.4 HT Tonga Green
What model is the pioneer jobby? And where is it mounted now? Can't quite work it out?! Smile 90 Puma HT
Post #144006 8th May 2012 7:44pm
With those subs that have been mounted to the rear of the bulk head where have the cables be routed to the front? straight through across and over or something different?
Post #144007 8th May 2012 7:49pm
ashfordsv
The speaker is a powered sub woofer (150 watts) link below:
http://www.easy-caraudio.co.uk/shop/subwoo...07725.html
Originally it was bolted through the bulkhead with the cable feeding under the the lip accross to the passenger seat and then down. The hole for the cables was drilled just under the lip so that they were not showing.
before:
It now sits directly behind the cubby box mounted on the remaining part of the bulkhead.
Post #144014 8th May 2012 8:18pm
RRUK
That 2nd photo looks like its repositioned on the inside of the bulkhead, behind the third seat.
I may be getting an aluminium chequer plate T chest for the winter so need to keep the back of the bulkhead free of stuff, no point having to mount it twice. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #144015 8th May 2012 8:22pm
ashfordsv
Your right, the speaker is on the inside of the bulkhead behind the cubby box/third seat. I have a box in the back as well, before removing the bulkhead i found the speaker stopped the box being opened fully but it was never a big problem!
Post #144019 8th May 2012 8:42pm
Jammer600
With your bulkhead removal, did you litterally just cut/jigsaw it off? And put a guard round? 90 Puma HT
Post #144036 8th May 2012 9:38pm
ngarigo
Ireland 2011 Defender 90 Puma 2.4 SW Santorini Black
hey ashfordsv.... what's the full rubber matting you have in the back of your wagon...? Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
'Wow...! What a ride!
MY11 90
Post #144046 8th May 2012 10:57pm
ashfordsv
Jammer, the bulkhead removal bar is from Mud Stuff UK, I got a local garage to do it all,
http://www.mudstuff.co.uk/Bulkhead_Removal_Bar.shtml
ngarigo, The load mat is from Craddocks:
http://www.johncraddockltd.co.uk/land-rove...odels.html
and the non slip mat is from Halfords
http://www.halfords.ie/webapp/wcs/stores/s...yId_212616
Very Happy
Post #144047 9th May 2012 12:55am
RRUK
It's as simple as that, or a mix of jigsaw for the bends and either a sabre saw or ciircular cutting disc. I'd like to do it but I think my mud stuff side panels overlap too much, plus my ECU and fuse box are mounted on my bulkhead, quite high up too. Sad 2016 D4 HSE
Post #144069 9th May 2012 8:46am
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
hi
bm52 answered it all... It's all conected to the radio, no need to get juice anywhere else...
I also fitted a pair of Sony Xplod (13cm diameter) in the roof cabin along with two pioneer at the front (standard 10cm diameter) plus two tweeters and the sound is great. I have no experience with alpine material, but I'm very happy with my set up!! Thumbs Up Great sound for the first time in a Defender! Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #144088 9th May 2012 10:51am
Naks
If you want bass without a sub/amp combo, try JBL GTO series 6x9's Thumbs Up --
Post #144092 9th May 2012 10:56am
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
i installed a small but massively basey set up for my single cab HCPU
you will never get decent base with out a sub. i tried a 4 channel amp powering 4 6x9's and it was laud but no base compared to a sub.
Pyle Chopper 1900w MonoBlock amp
anzar Vector 10" 500w Slim sub
and some VIBE Slick 4 Inch 4" 210w speakers in replace of the standard speakers.
running a pioneer x3 which puts out top quality sound.
Post #144185 9th May 2012 6:20pm
Page 2 of 4 <1234>
