Home > Maintenance & Modifications > A decent subwoofer speaker or a 'bassy' speaker?
Page 3 of 4 <1234>
chadjizz wrote:
i installed a small but massively basey set up for my single cab HCPU
you will never get decent base with out a sub. i tried a 4 channel amp powering 4 6x9's and it was laud but no base compared to a sub.
Pyle Chopper 1900w MonoBlock amp
anzar Vector 10" 500w Slim sub
and some VIBE Slick 4 Inch 4" 210w speakers in replace of the standard speakers.
running a pioneer x3 which puts out top quality sound.
Do you have any pictures of everything finished? Or is it a work in progress still? Thumbs Up
Post #144190 9th May 2012 6:37pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
regarding subwoofer/amp combo you could look at the Focal Bus 20 or Bus 25 - this is one of the smallest of its type but packs an excellent punch - selectable bandpass filter, remote gain control. I've bolted mine to the rear floor under the seat. Needs a 12V power supply
The fitter did recommend that it could be put in the space under the drivers seat but I didn't want it muffled, or rattling the other stuff. If you do mount something like this under a seat then be prepared to have 'good vibrations' coming up your backside - not everyone's cup of tea
I use an Alpine CDE 126BT head unit, 2x 3 way Pioneer rear pods mounted to the dog guard.......and Rainbow 2 way replacements for the under dash and tweeter replacements for the OEM ones
Post #144231 9th May 2012 7:49pm
WarPig
Re: A decent subwoofer speaker or a 'bassy' speaker?
RRUK wrote:
Now that I have installed my La Salle headlining and I have my 4 Alpine speakers wired up..
Any chance of some photos of your speaker positioning please? Thumbs Up
Post #144233 9th May 2012 7:56pm
landy andy
Post #144237 9th May 2012 7:59pm
RRUK
Loads of pics on the LaSalle Trim website now, in the customer gallery.
http://www.lasalle-trim.co.uk/customergallery 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #144300 10th May 2012 8:16am
RRUK
Decided to buy the Alpine SWE-1000, as it gets great reviews and I like the fact that all my equipment in the LR will be Alpine.
Thanks for the help chaps. 2016 D4 HSE
Post #144318 10th May 2012 9:56am
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
this is the finished article so far.
if and when i get my new 130 i will carpet rap it and put a leather cushion on the arm rest bit.
Post #144412 10th May 2012 7:29pm
farmer giles
i have an 8" JL 8W3 sub fitted face up in my cubby box. This is powered by a JL XD400/4 amp fitted inside the cubby box. The box lid is screwed down and the sound is excellent. this set-up was recommended and installed by the car hi-fi centre specialists and i am very pleased with it.
Post #144457 11th May 2012 8:43am
How wide is your cubby box to fit that? When I measured my standard one it was pretty much 6 inch wide so no good for that. Confused
Post #144469 11th May 2012 10:59am
RRUK
It looks like a bird box Shocked 2016 D4 HSE
Post #144490 11th May 2012 1:17pm
farmer giles
hi kona,
it went straight into the lid of the standard LR Cubbybox; i'm driving my 300tdi at the mo otherwise i would take a pic.
i have got a pic of my old sub in the back of the box on my td5 but i much prefer it in the lid.
Thumbs Up
Post #144494 11th May 2012 2:03pm
farmer giles
Post #144495 11th May 2012 2:05pm
So in your pic the sub is just under the 'cover' as such on the top of the cubby? Thank-you for the pic too Thumbs Up
Post #144498 11th May 2012 2:19pm
farmer giles
i believe on the 3 times i've had subs fitted to cubby boxes that they all have been attached to the inside face of the cubby box and then cover grilles fitted to the outside for protection (but i will check the puma tonight)
Post #144499 11th May 2012 2:31pm
Cheers, Much appreciated. Only problem with 8 in jobs is there is a limited range. I wonder if a 10in could be squeezed in or not shall have to check measurements. The hinges on mine would also need to be MUCH stronger Rolling Eyes
Post #144506 11th May 2012 2:48pm
Page 3 of 4 <1234>
