Home > Technical > Mantec and OE LR RAI |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
I`ve just taken my Mantec plastic jobbie off my Puma ready to part-ex it and i cannot believe how much better it goes without it It must have a massive restriction on the air flow
18th Aug 2009 7:31am |
ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517 |
S3d...considering the same, what did you do with the exposed rivnuts.
thought i might just roll some nice stainless dome heads into the nuts. |
18th Aug 2009 8:14am |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
I didn't notice any change in performance when I put the snorkel on.
Sonic - it's probably all the other weight you removed from the front bumper that made the difference Mantec has designed the snorkel with these engines in mind and they pay particular attention to the bore of the pipe. Given that it is on the low pressure side of the turbo, I doubt whether it really has a significant impact. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
18th Aug 2009 8:23am |
Thats exactly what i will be doing |
18th Aug 2009 8:47am |
Trust me it made a hell of a differance If you look inside the bottom of the snorkel its very restrictive |
18th Aug 2009 8:49am |
It is quite restrictive, I agree - but it also constricts further on in the intake (and obviously has to draw through the filter).
I'd have thought I'd see a drop in my fuel economy if my performance was throttled because i'd have to be giving it more gas. I've not seen any deterioration. Speed-wise, I still have the same sports car performance as before One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
18th Aug 2009 11:26am |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 |
I fitted one a week and a half ago, and performance hasn't suffered at all for me. Sadly, however, it does fit next to the windscreen in the exact place I used to grab onto whilst climbing in... Peter
2008 SWB Truck Cab 1952 80" Soft top |
18th Aug 2009 7:20pm |
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 |
Also did not notice any restriction in power etc
18th Aug 2009 7:31pm |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
Nor me with the OE version.
18th Aug 2009 9:08pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2445 |
So far these kind of RAI either keep or worsens engine performance. WOuld be interesting to know what happens with the Safari type on. Puma 110" SW
19th Aug 2009 12:08am |
beetroot Member Since: 15 Dec 2008 Location: manchester Posts: 41 |
Dont want to start a fight, but I have heard of quite a few occurences of puma engined vehicles going into limp mode as a direct result of restricted airflow through a snorkle.
19th Aug 2009 1:20pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 |
In our case, we didn't felt any problem in power using the Mantec one.
Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
19th Aug 2009 2:00pm |
RgrBox Member Since: 04 Jun 2009 Location: St-Cergue, Switzerland Posts: 111 |
The French Landrover Mag "Land" posted some interesting pics models info, and parts info concerning Snorkels, along with which snorkels made by Landrover go with which model and year..
http://www.discountpresse.com/land-mag-hors-serie,137620.html 2008 110 2.4 tdci csw Landrovers of Switzerland Club member |
19th Aug 2009 2:13pm |
