Home > Technical > Series Alternator conversion kit? |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 |
Anyone know anything about this conversion? buddy in USA trying to find this bracket (not sure whether he wants the whole kit if there is one) for a 1980 series 111 Santana 2.25 diesel land rover, this part is sold out in the USA apparently.
https://www.dropbox.com/s/lo7ybocivfk7qb6/...ersion.pdf I've emailled back for more infer re what he wants, but for the time being and ideas if such a conversion kit is available here or is it just a USA thing. Cheers DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
2nd May 2012 9:44am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6574 |
The supplier have relabelled all the parts to their own scheme, however all the parts except the alternator plug have LR part numbers:
Qty PDF No PDF Description LR No. Full Description 1 RNE135 Bracket ETC4357 BRACKET - ALTERNATOR MOUNT 1 RNC446 Adjuster Bracket 568789 BRACKET - ALTERNATOR ADJUST 1 RNC445 Alternator Pulley 568788 PULLEY - ALTERNATOR 1 RNC788 Alternator Fan AAU3956 FAN - ALTERNATOR - SERIES III 1 RNC347 Alternator Plug ? ALTERNATOR PLUG 1 RND251 Bolt BH108161L BOLT M8 x 75mm 1 RND250 Bolt BH605121L BOLT 5/16" x 1 1/2" 1 RNC908 Bolt BH605161L BOLT 5/16" x 2" 1 RNA964 Washer 2266L FLAT METAL WASHER M8 THICK 2 RNE475 Nuts NY605041L NYLOC NUT 5/16" UNF 1 RND253 Bolt BH605321L BOLT 5/16" x 3 3/4" 1 RND252 Spacer 574948 SPACER FRONT COVER If it's the main mounting bracket, then it's a standard LR part - common to the diesel and petrol. It's pricey new (£170+VAT) However, the 4 cylinder 90/110/Defender also used the ETC4357 bracket right up to and including the 200 Tdi which should make one easier to find There are a couple of Series items on eBay at the moment: http://www.ebay.co.uk/itm/320896518953 http://www.ebay.co.uk/itm/190671311202 There are earlier and later variations (not sure what the eBay ones are - Series III engine suffix C is the change point). All it does seems to change is the thread used for the longest bracket mounting bolt [aka RND251]. Early it's 5/16" UNF, later (as used in this kit) it's M8 - Defender will be later type too. The early bracket is 574855 instead of ETC4357, and the early bolt is BH605261L (BOLT 5/16" UNF X 3 1/4") instead of BH108161L (BOLT M8 x 75mm). The full descriptions should help you find generic replacement bolts instead of genuine parts if you want. 1988 90 Td5 NAS soft top 2015 D90 XS SW Last edited by Martin on 2nd May 2012 11:16am. Edited 2 times in total |
2nd May 2012 11:06am |
Thanks for that extensive information Martin, that might make it a bit easier for him to find what he wants as long as someone has one available.
2nd May 2012 11:35am |
Basically, any alternator-equipped 4 cylinder diesel or petrol up to and including a 200 Tdi will have the correct bracket.
Suddenly scrap engines are worth a lot more! 1988 90 Td5 NAS soft top 2015 D90 XS SW |
2nd May 2012 11:38am |
