Home > Technical > Series Alternator conversion kit?
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Anyone know anything about this conversion? buddy in USA trying to find this bracket (not sure whether he wants the whole kit if there is one) for a 1980 series 111 Santana 2.25 diesel land rover, this part is sold out in the USA apparently.
https://www.dropbox.com/s/lo7ybocivfk7qb6/...ersion.pdf
I've emailled back for more infer re what he wants, but for the time being and ideas if such a conversion kit is available here or is it just a USA thing.
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #142938 2nd May 2012 9:44am
Martin
Site Admin
The supplier have relabelled all the parts to their own scheme, however all the parts except the alternator plug have LR part numbers:
Qty PDF No   PDF Description    LR No.      Full Description
1   RNE135   Bracket            ETC4357     BRACKET - ALTERNATOR MOUNT
1   RNC446   Adjuster Bracket   568789      BRACKET - ALTERNATOR ADJUST
1   RNC445   Alternator Pulley  568788      PULLEY - ALTERNATOR
1   RNC788   Alternator Fan     AAU3956     FAN - ALTERNATOR - SERIES III
1   RNC347   Alternator Plug    ?           ALTERNATOR PLUG
1   RND251   Bolt               BH108161L   BOLT M8 x 75mm
1   RND250   Bolt               BH605121L   BOLT 5/16" x 1 1/2"
1   RNC908   Bolt               BH605161L   BOLT 5/16" x 2"
1   RNA964   Washer             2266L       FLAT METAL WASHER M8 THICK
2   RNE475   Nuts               NY605041L   NYLOC NUT 5/16" UNF
1   RND253   Bolt               BH605321L   BOLT 5/16" x 3 3/4"
1   RND252   Spacer             574948      SPACER FRONT COVER
If it's the main mounting bracket, then it's a standard LR part - common to the diesel and petrol. It's pricey new (£170+VAT) Shocked
However, the 4 cylinder 90/110/Defender also used the ETC4357 bracket right up to and including the 200 Tdi which should make one easier to find Smile
There are a couple of Series items on eBay at the moment:
http://www.ebay.co.uk/itm/320896518953
http://www.ebay.co.uk/itm/190671311202
There are earlier and later variations (not sure what the eBay ones are - Series III engine suffix C is the change point). All it does seems to change is the thread used for the longest bracket mounting bolt [aka RND251].
Early it's 5/16" UNF, later (as used in this kit) it's M8 - Defender will be later type too.
The early bracket is 574855 instead of ETC4357, and the early bolt is BH605261L (BOLT 5/16" UNF X 3 1/4") instead of BH108161L (BOLT M8 x 75mm).
The full descriptions should help you find generic replacement bolts instead of genuine parts if you want.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #142964 2nd May 2012 11:06am
It was never easy to find that bracket even in the UK , and is probably harder now. I have done several such conversions over the years, and used to try to keep a couple of the brackets 'in stock'; sadly they're all long gone.
It is however quite possible to fabricate a bracket to suit.
Edit - my post was concurrent with Martin's! Martin, thank you for an excellent and comprehensive post!
Post #142967 2nd May 2012 11:13am
d j hutton
Thanks for that extensive information Martin, that might make it a bit easier for him to find what he wants as long as someone has one available.
Buy British 🇬🇧
Post #142970 2nd May 2012 11:35am
Martin
Site Admin
Basically, any alternator-equipped 4 cylinder diesel or petrol up to and including a 200 Tdi will have the correct bracket.
Suddenly scrap engines are worth a lot more!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #142971 2nd May 2012 11:38am
