Home > Td5 > td5 mpg
Page 2 of 4 <1234>
JWL
Mine's generally around 25mpg, mud tyres, full length heavy roofrack, usually too much junk in the back and I do sometimes(too often Rolling Eyes )take advantage of the remap Whistle When I first had it remapped and less junk and "skinny" 7.50/16's with a road pattern I was getting close on 35mpg on a good run Thumbs Up
Post #142311 28th Apr 2012 9:49pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
Close to 40 mpg on 1.222 gears on a steady run in gear 5. Egr removed, mid box removed and stock tune.
Usually will manage 35 mpg on town driving.
Yes, the 1.222 does help.
Ambient temp ranges from 28 to 34 deg C
Defender 90. The defender has migrated, leaving the owner behind.
Post #142320 29th Apr 2012 2:11am
Herdwick
Generally average around 28mpg on mixed driving, can only just get 30 if driven very carefully, however it still seems to do about 26 even at a steady 70mph on the motorway.
Manage around 400 miles out of a tank.
Post #142380 29th Apr 2012 2:08pm
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
Laughing Well dont do 70 then!! 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #142384 29th Apr 2012 2:30pm
ciderdrinker
Wales 2001 Defender 90 Td5 CSW Epsom Green
may be worth fitting a disco tranfer box then! cheaper option than fitting an overdrive!
Post #142415 29th Apr 2012 4:37pm
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
In mine I used to get 26.5-28.5mpg, which I was reasonably happy with, bearing in mind it is an auto and generally auto mpg isn't as good as a manual.
Since fitting the roll cage though I am getting a pretty steady 25 mpg. Not so happy Sad
Post #142420 29th Apr 2012 4:52pm
40mpg Shocked Is it all downhill in your part of The world? Darren
Post #142421 29th Apr 2012 4:53pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Did LR design all their engines to have very similar MPG. My 300 did similar MPG to those quoted above and my Puma is similar as well. Best i have had in the 300 was nearly 30 and same with the Puma. Worst mid 20's. BM52
Post #142428 29th Apr 2012 5:16pm
Laurie
My 5 bearing 2286cc in a SIII 88" PU only ever managed 22 mpg.
If I pushed it it went down to 18.5 mpg.
Max with overdrive 65 mph.
They have inproved a bit since then
Post #142430 29th Apr 2012 5:38pm
achuakh
Sounds amazing, but it's 14km to 1 litre. That's at 1970rpm. Which gives me about 90km/h. Gps tracked
40L gets me 580km. Yes, we are talking about cruising in 5th. Just go gentle on the right foot!
So let's take things a ill less positive with 530km So it's about 13km/l which is still pretty good.
Vehicle is on 235/85/16 general grabber.
10yrs, my2002
Serviced at 10k km interval full syn oil.
Conversion table http://www.mpgtokpl.com/ The defender has migrated, leaving the owner behind.
Post #142528 30th Apr 2012 12:56am
RobKeay
Got 36 a couple of times. Average was 28 lowest 22 pulling a heavy cherry picker. All standard apart from MTR tyres and a snorkel.
Post #142533 30th Apr 2012 7:21am
Ah, so that's just at that sort of steady speed? Most folks quote MPG as an average from one tankful to the next, which takes into account the wide variations between accelerating and coasting, hills, etc. Darren
Post #142536 30th Apr 2012 8:43am
alanhid
Scotland 2006 Defender 90 Td5 XS CSW Bonatti Grey
Been on holiday this past week and did just over 600 miles on the west coast of Scotland and averaged 31mpg..... Razz Life is not a rehearsal!
Def 90td5 CSW xs 2006
Post #143493 5th May 2012 11:06am
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
Used to get 31mpg out my old 90, and that was on country lanes, but straight-throught exhaust, silly filter and viscous fan taken off.
New 110 (still a Td5) gets closer to 28. Snorkel doesn't help though. Soon to get a freer-flowing exhaust and a remap to help thing out Cool
Post #143545 5th May 2012 11:46pm
ciderdrinker
just worked out on my last tank i managed 29.1! quite pleasantly surprised! 90 td5 csw
90 200tdi
series 3 petrol
series 2 diesel
series 2a v8
Freelander 2
Post #144881 14th May 2012 11:21am
Page 2 of 4 <1234>
