Home > Maintenance & Modifications > Security nuts
Security nuts
Does anyone know if this: http://www.devon4x4.com/index.php?option=c...;Itemid=14 Will fit on to this: http://www.firstfour.co.uk/item/1886734/de...overy-eyes The same bumper as I have. Reason for asking is there isn't a lot of room to fit full stop. So if anyone has any of these security nuts could I please have the dia / measurements.
Thumbs Up
Post #142073 27th Apr 2012 12:10pm
Having the holes in I would have thought it was an easy job to chisel them off with a centre punch and hammer ?
Post #142075 27th Apr 2012 12:14pm
Post #142077 27th Apr 2012 12:18pm
I don't quite follow you? The bumper I have already has the holes in thats no problem. The nut size I also know which is no problem. All I want to check is that the outer diameter on the Security nuts as the area they will have to fit is fairly tight. It looks quite obvious that they are slightly wider than a regular hex nut. It's just the edges of the bumper bracket that get's in the way.
Post #142078 27th Apr 2012 12:18pm
Just noticed your link. Trouble is with those is that it would be easier said than done to remove those as some times they do have to come off
Post #142079 27th Apr 2012 12:20pm
konabikes11 wrote:
I don't quite follow you? The mumper I have alread has the holes in thats no problem. The nut size I also know which is no problem. All I want to check is that the outer diameter on the Security nuts as the area they will have to fit is fairly tight. It looks quite obvious that they are slightly wider than a regular hex nut. It's just the edges of the bumper bracket that get's in the way.
Sorry, I haven't helped with your question regarding size Embarassed
What I meant was that having the holes in the nut (the holes that the 'security key' fits into) made it easy to undo them using a centre punch and hammer
Post #142081 27th Apr 2012 12:22pm
Ah I see your point now Thumbs Up
Post #142089 27th Apr 2012 12:40pm
bob neville
Have a look at these Thumbs Up
http://www.ahc-camberley.co.uk/catalog/pro...mp;sort=1a
2013 Defender 90 CSW - sold
Post #142097 27th Apr 2012 12:53pm
Bob
Thanks Bob, Trouble is with the tool cost on top it's even more expensive. Anything is better than just the hex as it would be off in a matter on minutes if that Confused
Post #142110 27th Apr 2012 2:11pm
bob neville
Agreed, the tool is expensive Shocked
Just email Devon 4x4, they will get the dimensions for you.
Post #142113 27th Apr 2012 2:29pm
Bob
I shall try that. Shame it's friday now though never mind. How's the new 90? Thumbs Up
Post #142122 27th Apr 2012 3:12pm
bob neville
Good thanks Thumbs Up
Still in the health farm, juat waiting on the exhaust being fitted I think so hopefully back with me next week.
Post #142135 27th Apr 2012 3:53pm
Bob
Great news. Having anything different fitted or just standard LR? Thumbs Up
Steve
Post #142137 27th Apr 2012 4:02pm
bob neville
Hi Steve
Off Topic
Different Thumbs Up
Custom made SS, no decat or centre box. Slightly (very) more expensive than off the shelf but I have been told it will sound good, ear defenders on order Laughing
EGR removed, all fluids changed, braided brake hoses, damn good service (I was told it was needed !) and front rear pinion leaks done. Rear X member not replaced now as I was told it has quite a few years left in it, just one area needed sorting. Bit of bulkead damage fixed plus a few other small jobs.
Should be mechanically sound when it comes back which is exactly what I wanted Thumbs Up
Two new doors sat here all sprayed ready to fit when it returns then the fun begins !!
Just got to source a new front and rear headling. Fingers crossed I have sourced front and rear brand new take off's, rear is with my source just waiting to see if they can get a front. Lot cheaper than Le Salle.
Post #142143 27th Apr 2012 4:57pm
Bob Off Topic
I was thinking about the EGR on a TD5, instead of removing all the bits, can you disable it by disconnecting the actuator pipes?
Post #142208 28th Apr 2012 6:35am
