Home > Puma (Tdci) > Puma Gearbox
MK
Puma Gearbox
Hi guys:
How many of Puma owners have/had issues with the gearbox?
thanks
MK Puma 110" SW
Post #14049 10th Aug 2009 10:22pm
BigGeorge
Switzerland 2010 Defender 110 Puma 2.4 SW Keswick Green
well... I had
after about 10'000miles my clutch was replaced (together with rear diff). A few weeks later LR acknowledged that the gear box was finished too and replaced it.
So far no specific issues other than some noise when going faster
George The goons are trying to bring me down!
Defender 110 SW MY10 useless piece of Censored ... but I like her
Defender 90 V8 50th Anniversary
Series IIa 109 / 6 cyl. ex-fire truck
Post #14050 11th Aug 2009 3:40am
Pauly
Germany 2007 Defender 110 Puma 2.4 SW Java Black
@BigGeaorge
what was the reason/diagnosis for the faulty gearbox?
Pauly All science is either physics or stamp collecting. (E. Rutherford)
Post #14053 11th Aug 2009 7:56am
Higgers
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Firenze Red
just had the clutch replaced and its completely transformed the car.
Before i had loads of gearbox noise, now its silent.
Ian
Post #14054 11th Aug 2009 7:58am
Fontuin
2008 Defender 110 Puma 2.4 SW Zambezi Silver
My clutch has been replaced twice, both times due to loose pressure plate springs causing a very noisy rattle.
LR seem to be strugglng to sort this one out because my second clutch also rattles although it is a lot quiter than the first two, I'll have it checked out at my 50k(km)service again.
The replacement clutch that does not rattle(rattles less) has transformed the vehicle.
Post #14057 11th Aug 2009 8:07am
CapeLandy
South Africa
Mine had a terrible rattle which was sorted for a while with the revised clutch and pressure plate.
Noise is back and getting worse.
I think the gearbox or clutch is shot.
I need to take it further because dealer insist they can't hear it. Puma 110 - gone
Series III 1973 - going strong
Post #14058 11th Aug 2009 8:08am
Grockle
Do you all tow trailers etc., if so that may be the cause,I know thats what a Defender is for but just wondered. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #14063 11th Aug 2009 9:04am
Fontuin
I do. I towed a 2.6 metric ton load 500km this weekend again. How could this be the problem?
Post #14064 11th Aug 2009 9:39am
Grockle
The early trucks had Transit clutches in and weren't up to the job,that's why I asked. Thumbs Up 2.4 90 XS
Post #14065 11th Aug 2009 9:53am
Bosun
2 new clutches, new gearbox, new transfer box, 2 new rear half shafts and it still drives like it's 15 years old and the gearshift is worse than ransid pants!
Bosun.
Post #14066 11th Aug 2009 10:11am
slocum
Clutch replaced, gear box replaced, transfer box replaced, front shaft replaced, rear diff replaced. Now I'm waiting for a complete rear axel.
Post #14067 11th Aug 2009 10:29am
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Clutch replaced on mine i tow the limit and more every day and after i had a new clutch
replaced iv had no problems whatsoever,
before the clutch the transfer box gear stick use to rattle like faaaarrrk NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #14068 11th Aug 2009 12:01pm
Happyoldgit
Clutch replaced at around 6,000-8,000 miles.
Post #14078 11th Aug 2009 2:27pm
mse
None of you have had the selector replaced i see and this is a common part.
Ive had a new clutch and they broke the selector and the 2 have changed the car (i drove it on the broken one...no big deal change wise)
I also had to have a new selector plate about 6 months ago when there was a rattle but they wouldnt do the clutch - that changed things.
I wonder how many just need this change?
The new modified front prop also helped when the nipples dropped out of the last one. Mike
Post #14081 11th Aug 2009 3:42pm
CapeLandy
South Africa
What test can we do to eliminate the selector being at fault Question Puma 110 - gone
Post #14082 11th Aug 2009 4:00pm
