Home > Maintenance & Modifications > small amp idea
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
small amp idea
Hi all need some idea tuning if we can.
I have in my 90 a nakamichi cd400 head unit which is a belter but is also a bit redundant as all it does is act as an amp for my wildfire s via the aux input. So this set me to thinking why not just have a baby 2 channel amp fed from a jack plug; it can then just hide in the bottom of the dash tray no moving parts so less bothered by muck and dust hidden from view and affording a bit more space for hammer and nails and foot shears and such.
So I need some advice on what to buy and what not to in the world of low power compact stereo amplifiers. Please and thank-you. Rhubarb and custard let fly with their secret weapon.
Post #139466 15th Apr 2012 8:32pm
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
Theoretically could be done, however it depends on the amp as some will only have RCA jack outputs, especially if it is small. to be honest, it'll be easier to just leave the Headunit as it is, as you're going to have to butcher the wiring to get the right connections. If you want more power, just add an amp behind the head unit!
Alex 110 Tdci Double Cab
Post #139518 16th Apr 2012 8:35am
K9F
Hi Lambert,
I fitted one of these behind my head unit, super slim and ticked all the right boxes. Kept 10cm speakers and sounds great.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #139549 16th Apr 2012 11:24am
lambert.the.farmer
What about one of these?
http://www.virtualvillage.co.uk/2-channel-...pping_feed Rhubarb and custard let fly with their secret weapon.
Post #139599 16th Apr 2012 4:31pm
ZeDefender
*deleted due to getting carried away* Tell someone you love them today because life is short.
Post #139614 16th Apr 2012 6:06pm
K9F
I think you pays your money! You gets your choice! Do a Google search and get reviews on prospective choices. It looks 'cheap and cheerful' and that's exactly what you may get. 20 watts rms may be sufficient for your needs if your Defender is running sweet as a nut but I would suggest a minimum of 40 would be better to drown out all the creaks, rattles and groans and not just from the missus....
Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #139707 17th Apr 2012 3:15am
That's exactly what a friend of mine did in his 90. had an amp mounted behind the cubby box (on the bulkhead), quite a beefy one running a pair of 6x9's and a crossover to a sub.
Just had his ipod connected on a flylead in the cubby box. He could adjust the volume on the ipod or turn the gain up/down on the amp.
So no stereo in the dash to be seen/stolen etc.
On my stereo, i mainly listen to music i've downloaded onto a mem stick, but occasionally I like to listen to real time radio, so keep a "normal" stereo in there.
Post #139723 17th Apr 2012 6:37am
lambert.the.farmer
That's interesting cos I have a Genesis amp from back in my scooby days. Might have a go at putting that in see how it likes it. Cheers. Rhubarb and custard let fly with their secret weapon.
Post #140010 18th Apr 2012 5:36am
cradgebank
England 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Have you fixed your starting problem Lambert ? Richard
Either a 90, 110 or 130.
Discovery 5
Post #140014 18th Apr 2012 5:57am
lambert.the.farmer
Not got new pipe yet but the emergency bodge has made it way better. Rhubarb and custard let fly with their secret weapon.
Post #140025 18th Apr 2012 6:44am
